2000 Acura 3.2TL Timing Belt
I'm trying to minimize cost. Other than the Acura OEM, what replacement brand timing belt including water pump and belt tensioner would you recommend for my 2000 Acura 3.2TL? I've surfed through several brands and what interested me was the Aisin brand.
Welcome!
Scroll through even the new threads that are posted!
and look in the DIY sticky thread at the top. Linked here for you: https://acurazine.com/forums/2g-tl-1999-2003-98/new-official-2nd-gen-tl-diy-thread-706083/
The forum specific search should yield you plenty of results as I have seen 3 threads on the front page alone.
good luck!
good luck!
The Aisin 5 piece kit (tkh-001) does indeed contain the OEM parts for our cars. Search online for the best price. And yes....you need to replace all 5 parts. I would also replace the crank seal while you're at it since it's right in front of you during the install...
Yeah, as these guys said......go with the full "Aisin" T-belt/component kit for best results.
End of Discussion!
don't forget new ngk irids at 8 bucks each, a 7 dollar PCV valve and you may need valve cover bolt gaskets if you see any oil leaks around them now
Seafoam is your buddy for internal cleaning of engine pre-service
if diy'ng the project- do the valve adjustment and clean the egr system inside intake manifold- which will be off for valve adjust--combine your labor
makes a TL like new at 150kmiles!
cleaning the throttle body internals and IACV are done when manifold removed
Hey guys so I was going to get my Cams replaced as well and found this deal.
Should I get this and get both of them done at the same time while its open?
http://www.ebay.com/itm/GENUINE-HONDA-Cam-Camshaft-Crank-Crankshaft-Seal-SET-Timing-Belt-Service-Kit-/151148156060?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2003%7CMake%3AAcura%7CModel%3ATL&hash=item233121d49c&vxp=mtr
justnspace (03-05-2014)
Personally, I usually don't bother with the cam and crank seals until the second t/belt (200,000+ miles). If you go that far, you should also replace the oil pump to block gasket.
SpringRubber (03-07-2014)
saberlove
03-11-2021 09:29 AM
Mike Bertram
09-10-2015 09:27 AM
Phambam12
09-05-2015 04:10 PM
asahrts
09-04-2015 05:55 PM
