100,000 mile maintenance
![Unhappy](https://acurazine.com/forums/images/icons/icon9.gif)
So my 03 TL that I bought in July 02 has over 100,000 miles on it now.
I took it to Pep Boys yesterday to get all the maintenance done (didn't even bother going to the dealership).
Here is what I asked them to do:
Replace timing belt
Replace spark plugs (platinum)
Oil change (synthetic)
Flush/replace coolant
Flush/replace transmission fluid
Flush/replace brake fluid
Replace rear brake pads
Rotate tires
The estimate they gave was $400 for parts, $900 labor (not including timing belt kit which they did not have in stock).
They called me this morning and said they could get the kit from Acura for an additional $300. They also said I need to replace 3 motor mounts (parts $400, labor $350). The transmission has been very clunky so I believe this.
That brings the grand total to $2350. Does this sound reasonable? If this is how much they charge at Pep Boys, I hate to think how much the dealership would charge!
Replace timing belt
Rotate tires
No not reasonable at all. whats with the additional 300 for the timing belt kit?? Shouldnt that have been factored into the original estimate? You can buy the parts needed for the timing belt cheaper yourself, The motor mounts shouldnt cost more than 200-250
Buy the parts here.
http://www.acuraautomotiveparts.org/...catdisplay.jsp
Change the oil and trans fluid yourself. Make sure the trans fluid is honda fluid. Both ae very simple to do, and if you do bring it in, DONT do a trans flush, do a drain fill
Buy the parts here.
get away from pep boys!!
A private honda acura shop is what you need
Those pep guy are guessing- they dont know what parts to order- wont use NGK plugs, probably use Dextron trans fluid and other bad things
Look in the real phone book for a place with pic of acura/honda in their ad. They are everywhere
I'm about to order the parts for my 100k mile timing belt... I think you should do some more reading into this... The price seems kinda high
click on search the forums and type in timing belt or something.... Everyone's cool on here with good advice if you do the research on here...
I would get a couple more quotes from local mechanics who work on foreign cars for good measure...
timing belt normally seems to be around $600
its more than just the timing belt.
You are supposed to do the water pump, and its a good idea to replace all the belts and tensioners while its apart. Then a proper 105, gets a valve adjustment, and many of us would pull the intake manifold and clean the EGR port as well
It may be well worth your time to check in with your local Acura dealership for price comparison and actual maintenance required. They can provide an itemized list of all necessary parts and be of great assistance with any factory recalls or extended good will warranties. However, as mentioned before, it's always more cost effective to do the minor things yourself and expedite the timing belt project to a reputable independent shop in your neighborhood. Providing "OEM" Acura parts is always in your TL's best interest. Tires, brakes, suspension, fluid changes & tune-up can be competitively priced at most any local shop.
Originally Posted by burnerjunky
how do you drain fill the tranny fluid
Buy the parts here.
Buy the parts here.
Honda fluid is so crappy that any fluid might be better than it.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Originally Posted by DUI4Less
Can't agree more. If it wasn't for warranty issue, I would not use honda z1 period; crap crap fluid.
Got a quote from the dealership to replace timing belt/water pump/belts for $750. Made an appt. for this Thursday.
Well, guess what happened over the weekend? The transmission started slipping big time, so I called the dealership to see if I could drop off the car earlier to get this checked out.
So I drop it off yesterday (by the time I got there, D5 was blinking and I couldn't even get out of 1st gear) They said the transmission is completely shot and needs to be replaced. Warranty will cover the cost of a remanufactured transmission and I will pay $600 labor.
I get the car back in 1 week and in the meantime, they gave me an 08 TSX with nav as a loaner.
Re parts:
rear brake pads @ $35
platinum plugs _ I recently put in Bosch platinum @ $6 each (I think NKG Iridiums are original equipment - they're @11 each)
Synthetic oil - Walmart has 5 qt. jug of Pennzoil full synthetic for less than $20 or Mobil 1 for about $22.
Coolant - 2 gal. premixed for @$10 or $11/gal.
ATF - Honda ATF Lists for @ $6 +, buy it at a Honda dealer (not Acura). I paid $4.75/qt. capacity is 7.6 qts. but you only get about 3.2 out when you drain and refill.
Brake fluid is cheap - Honda or Dot 3 @$5
Timing belt - not sure but I recall that my dealer gave me a $100 certificate and I got drive belt, timing belt, radiator hoses, and a gal of coolant for that.
I agree that it makes sense to change the water pump ((I think I paid about $80 for it) when the timing belt is changed.
So the bottom line is that the parts shouldn't cost you more than $200 - $230.
I agree with the suggestion that you change the ATF and oil yourself. It's easy. By the way, your owner's manual recommends not flushing ATF - rather you can get almost all of it out by draining and refilling three times.
which dealer did you use? Ferman Acura? My car needs the timing belt and water pump replaced too. thanks!
OMGWTFVTEC
can I purchase/do all the 100k maintenence myself? Well, with the exception of the timing belt... last thing i want to do is not do it right and cause more problems than i started out with...
Here is another source for OEM parts:
http://www.acuraoemparts.com/delray/jsp/home.jsp
socko:
get those Bosch plugs out of the TL
NGK Iridium are 7 bucks each at major name parts stores
only NGK or Denso are approved for use in the Acura
It does make a differance- other users thought they were fine- then mileage went down and plugs crapped out
Are the Bosch a 1 super fine wire or their 4 chuncks of metal type?
Originally Posted by socko
01tl4tl:
I've had the Bosch plugs for about 30xxx miles and they're doing just fine, thank you. If I had found NGK locally here in NE Missouri, USA, for $7 I would have used them.
but you'll probably have to change them soon, as opposed to the NGK's which last a longer time.
The Bosch plugs seem to last in applications where the ignition system doesn't fire in reverse polarity (like they do in some GMs).
No guarantees about the CEL though.
Registered Charity
I just had the 105K service done, although my TL has 115K on it. Local mechanic who I use regularly wanted $1,050 to do the timing belt, water pump and tensioner.
Local Acura dealer wanted $1,090 and gave me a loaner for the day. It included a bunch of other stuff ("lubricating all moving parts" whatever that translates to) and other nice add-ons that they throw in there to make you feel like you're getting your money's worth.
It took most of a day, and with a new side engine mount it came to $1,399.
I use a local mechanic for almost everything, but for a job like this, I'd rather the Acura mechanics, who take them apart and put them back together all day, handle it. Plus, the free loaner saved some hassle.
Not a big fan of dealerships, but for stuff like this, I do. Good luck!
all moving parts- they lubed your door hinges and that sort of thing
Sometimes the dealer is actually a deal- who would have known.
I do agree that I want someone who does many of these a year, and doesnt fumble and wander as he learns on my baby
I went to price the 105 for my car and they guy looked out the window at it,
~hmmmm you got some money invested in this car!
Reckon that'll run a few hundred extra~~~
03 acura tl type s with 45,000 miles
our acura dealership has recommended the 7 yr. / 100,000 mile service. my 2003 tl type s has 45,000 miles. should i do the service now or can i wait? and how long can i wait if that is suggested?
8th Gear
Not reasonable at all.
I also have a 2002 acura tl type-s that was purchased in october 2002. it just hit 101,000. i replaced:
Timing belt
2 drive belts
timing and drive belt tensioners
water pump
flush out transmission fluid
flush out coolant
tire rotation, balance and alignment
all parts were bought online, and all labor was done at a private mechanic. EVERYTHING was approx. 1000.00.
900 dollars in labor is RIDICULOUSLY expenseive. even for a pep boys.
Timing belt
2 drive belts
water pump
flush out coolant
Volks FTW!!!
let's make this short and simple. DO NOT GO TO PEPBOYS. they have no idea what they're doing and if you're asking them to do a more complicated task outside of an oil change and tire rotation, they will f*ck it up.
labor at $900?? you gotta be joking my friend.
if you really don't want to see a dealership, take it a certified honda/acura shop. they will know the ins/outs of your car better than pepboys.
Had my timing belt, tensioner and water pump replaced at 110,000 for 800 bucks by Motorworld in Wilkes Barre - my local dealer wanted 1100.
Plugs and trans fuild are easy DIY things...
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
