1/4 mile times
1/4 mile times
HEY guys i have a 02 tls with aem intake comtech headers and exaust and im goin to put pulleys on the car. witht the 3 options above i took my car to englishtown raceway tonight. low and good huminity but the times were surprising. 1sy run was 15.1 2nd was 14.9 and 15.0 for the last run. the car was warmed and cooled after each race so fatigue on the engine is not a factor. i think that the stock one will run in the 15.5 range and the manufactor ratings are over rated. good news is that i beat 3 wrxs that i raced againt most had minor work to them but were all in the 15.2's. Also does ne1 with similar work on their tls have times for 1/4 mile i would like to know how u have run. thanks marc
2005 SSM/EB/5AT/Navi
I tried to goto the track tonight but Tropical Storm Edouard beat me to it.....so it looks like i'm going to have to wait until Saturday Midnight races at Orlando Speedworld.....hopefully mine runs high 14's - low 15's...........good runs man!!
Good runs? Those runs suck ass. You should be around 14.3-14.6 with headers alone!! Something is wrong with your car man. I ran a 15.0 with just a intake.. and my buddy has headers, intake, exhaust, pulleys.. and ran the best of 14.3. Try to see if your actuator is working right... here you can read up on it, and shows how to check it.
You beat WRXs...interesting...
Oh and dont get pulleys.. they dont do $hit.
http://www.geocities.com/gamesmgr/chod/acura/#Driving6
I don't remember if I ran my car stock or not, but with a Comptech header I ran 14.8 @ 94.2. Adding the Injen intake netted me a best of 14.6 @ 95.5.
EDIT: FWIW, all runs done at Moroso Motorsports Park in Palm Beach Gardens, FL.
still a Masshole
I ran a 15.2-15.4 Bone stock without having taken anything out or adjusting tire pressure on an 85 degree night and mild humidty. I am pretty sure on cool night with some tire pressure adjustments I can break the 14s. With headers you should be in the mid to high 14s, which you did. I think in cooler weather and with better rubber you should be able to get into the low to mid 14s. A few guys have run 14.6-14.8 with just and intake while most BS TLSs run in the 14.8-15.2 range.
Try it again when the weather is cooler!
Im not suer how to check
im not sure how to see if the acutator is workin or not there are no directions on the page on exactly how to do it. can u tell me how i can check to see if it is working step by step, yea i thought that car should run at least in the mid 14's
not to mention the east coast tracks are supposed to be
pretty fast. There has to be something worng with your car. What are your trp speeds? If you are at 93 mph or less you aren't making the hp you should be making. What is was your tire pressure? 60 ft time? I beleive Ferixxo's best times came with a 60 ft of a bout 2.3 or 2.2. If your tire pressure is too high up front traction woudl be an issue.
Re: Im not suer how to check
i checked the car
I checked the piece that i was told to check and when the rmps are at 4200 or around there the valve does open up. what should i do now, the cars vavle does open up and the tire pressure was at about 31psi when i ran ne advise on what to do now, and i preloaded to about 2500 rpm when i started.
That's weird! Your car should definately be running better than that! I wish i could have gotten to the track lastnight so i could see what mine is running...it's stock. Wanted to see what it ran before H/I/E were installed......by the way...Less tire pressure the better......i had mine down around 15psi...more rubber on the pavment the better...A MUST w/ stock tires.
still a Masshole
Originally posted by FugittiveTLS`03
MAKE SURE YOUR (VSA IS OFF!!!!) Major 1/4 mile time killer
Ok guys... all that said... how the hell does Motor Trend get a stock TLS to 14.7 @ 97 mph? I suppose their optical 5th wheel could be more acurate as the timer isn't going to start until it starts rolling... but I can't think of anything else that could attribute to that time. Save maybe... they just ran the car on a cool, dry morning with temperatures around 50-60 degrees or so. I know mine flies in those conditions. Any thoughts?
4dr & I like it that way
definitely turn traction control off
and while the AEM pullies might not do anything, the UR pulleys (the crank pulley) provide a nice power increase. a guy on the CL-S board ran 14.3 with just the UR pulleys tires and a CAI I believe
GO SEMINOLES!!!
Sure thing man!! I've been trying to go for the past 2 weeks
Wed. & Fri. 6pm-10pm $10 to watch $10 to race
Sat. they have midnight races also till 2am
Let me know!
Let me know!
GO SEMINOLES!!!
Originally posted by juniorbean
exhaust does nothing, so it wouldn't make a difference.
14.2 still seems pretty fast.. one of the fastest I've seen. Who posted that time... do you remember??
whoops its a 14.3 by mattg here the thread for refference, and I guess he did have headers after all
http://www.acura-cl.com/forums/showt...7&highlight=UR
UHH
you talk like you car is super fast cause it ran 15.0 with just intake....I will roll out on you with what ever you bring to the line...Ohh and good time to the guy that started this thread...
The real "mag-racers..."
...like C&D .. in their October issue they post the TL Type S at 16.0 seconds to the quarter, and 7.4 to 60 .. but.. hmmm.. in the SAME issue, in the "short take .. Maxima SE" .. they talk about how the TL-S nearly edges the Max 6-spd (that ran a 14.7 in stock trim w/ 255 hp) running a 14.8 and 6.2.... that's the magazine editors themselves contradicting .. THEMSELVES. They had a range of 14.8 to 16.0. There 0-100mph in the TL_S ranged from a best of 16.0 (in their first full test) to a 20.8 seconds in this October issue. Oh yeah, the trap speed for October was only 88mph... I've seen better numbers for the TL-P!! However, to be fair, it's important to note that ALL the cars they tested that day were running ridiculously slow .. like the G35 running the 15.6 ... The Bimmer was running well over 15.5 ...
Re: UHH
OH and Snowdude actually beat his time of 15.0 w/ a 14.9
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
