03TlS Main Req'd light came out any idea why?
Tl fever...cureless!
1 Post
HI guys i have a 03 TLs ..heres what had happened! I got Stuck in Flood water (Not too bad) and i had to replace my starter and car ran fine for 2 weeks! i had just did mobile 1 oil change about 2 months ago more like 1300 miles ago!
Now yesterday My Maintaince REquired light came out!
Any idea what it can be or just do a oil change again?
Thanks for all help
Thanks for all help
2000 acura tl FPR
Thanks for all help
Thanks for all help
iirc, you put key in ignition, hold both trip/reset buttons, turn the key to the on position and the maint req'd light will flash a few times then disappear. correct me if i'm wrong.
1 Post
ok but right after oil change light was gone for 1500 miles and it just shart showing up and its not flashing btw! its Solid! but i wil try to reset how u said and see what happens!
Because it was never reset when the oil was changed. That light is NOTHING more than a dummy light. It doent mean any thing is wrong and will ONLY tell you that you need to change your oil when its reset at every oil change. It is preset for 7500 mile oil change intervals(which is what the manufacturer recommends), not 3000. There is no way of changing it. Reset it and it will be gone for the next 7500 miles.
rockyboy
12-06-2022 02:29 PM
rockyboy
01-25-2016 06:00 PM
