03 Type-S Radiator and Condenser Fan Questions.....
I had an issue with my condenser fan and had an overheating issue....long story short I did a full coolant flush, new radiator etc. Ended up replacing the condenser fan with an aftermarket motor anyways I was out bleeding the system and waited for the car to reach normal temp and for the fans to kick on and I never really paid much attention to the fans but does both our fans kick on at the same time or is it just the drivers side that should kick on and the passenger for backup or when the AC is on? Mine appears to be both at the same time. Can anyone confirm this?
Our TL uses both at the same time just at different speeds..
For AC On uses about 25-50% Both fans output at a given set time..
You needed to reach the Heat Mark which uses 100% both fans and the ECU controls for how long they will kick in.
