03 TL-s 69k tranny went/Acura covers 50%
#41
i'm still a little confused w/this whole trans problem... i called in and they said my tranny wasnt affected. I have an 03 TL-S. is it true it was some and not all?
#42
The dealer for my car basically said "we'll warranty the tranny if you do a timing belt job here". The odo was at 109k when the tranny failed.
We're 3K miles and 7 months away from the 3 year/36k mile warranty on the remaned tranny now.
#44
white pearl
all of the have gen have the recall to install an external oil jet kit to spray trans fluid at the 2nd gear shaft- located under the normal filler hole
the other part with 109 is a court case lawsuit against honda for early failures
They needed a VIN to settle the case- so one was picked
It in no way was a change or fix to the trans
The ones replaced after mid 2005 seem to have a different new case with better oil flow- as they are doing much better than originals and pre 05 replacements
If you are `not covered vin' it simply means extra work on your part to get `Goodwill warranty`- out of acuras pocket instead of yours
Does not mean your trans is better than the next or prior one
MetalGearTypeS
08-29-2016 08:28 PM
InFaMouSLink
10-27-2015 06:52 PM
