Will these rim fit my car?
Can somone please tell me if these rims will work on my 08 RL. Im not sure what rims I can put on my car because of the spacing and the all wheel drive.
Thanks for your input!
http://www.victoriatire.com/wheel_MRR_HR%206
The website indicates all sizes will fit, but since they incorrectly list a 20x10.5 wheel being able to fit, I wonder...the 25 mm offset is about right for 10.5 inch wheels, but a 62 mm extension out toward the fender is a lot, I am not sure there is that much clearance, especially if you lower.
What does the manufacturer say about fit?
Make sure you get centering rings and TPMS if you buy.
AWD recommendations are same size wheel and tires on front and back vs a staggered set up
Make sure you are aware of your tire choices and tire prices, as 19's are somewhat limited in choice when compared to 18" rubber and even to some extent when compared to 20" rubber
I would also check and see what your weight penalty will be with these wheels.
I believe the last person to fit 10 inch wide wheels had rubbing issues.
Bottom line, get a fitment guarantee from the retailer, and the ability to return or exchange the wheels...
merc009
10-03-2015 12:59 AM
