Will aftermarket M3 rims and tires fit my '05 RL
There is a guy that's selling some aftermarket 19"s that are 5x120. He's about 1 hour away and I've only seen pics and talked to him. He had them on his M3 (not sure what year). Would they fit my '05 RL. I know that the bolt patterns are the same, right? But I'm worried about spacing.
19xwhat? What is the offset? Who makes the wheel. Go back to the manufacturer and see what they say about the fit. They may not know, but unless you ask...
I would also worry about the tire size. What is it? Worry is too strong...consider the tire size...of course the wheel is the most important.
You may just have to drive there and do a test fit.
I believe they advise against it for the Acura AWD, but that said, others have run staggered setups on TL SH-AWD and RL, The minimum consideration is that the tires must be the same rolling diameter, which is how staggered should work, but people often do whatever they want...
M3 wheels on this RL so the G37 wheels should work?
I found this RL on Cardomain with M3 wheels staggered and they fit.
http://www.cardomain.com/ride/3380732/2005-acura-rl
buy mine, they are not staggered either.... https://acurazine.com/forums/car-parts-sale-361/19-m3-style-wheels-rl-799551/
I have this wheels already 19 staggered want to know if they fit.
I already have this TSW Catunlya 19' staggered wheels off my G37 that I want to place on my 05 RL. I just need to know if they can fit. Please help me out fellas.
As said before, the bolt circle and the hub are wrong sizes. You could try adapters or drill out the bolt circle. You would also have to check the rolling diameter against that recommended for the RL. You do not want to vary more than about 2% from that diameter.
I found this wheel adapter below for RL to change 5x120 to 5x114.3 on ebay. Let me know what you guys think? Thanks!
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
A- HUB sizes for those Nissan Wheels. Our RL hub = 64.1mm
( In case U have to buy hub rings )
B- Bolt Patter of nissan wheel (5x114 ) ours Rl = 5x 120
C- Off Set I beliebe everything over 35+ will fit. My M3 replica are Off set = 35 with front wheel wide =8.5
trinikidcl
09-04-2015 12:56 AM
nuldabz
09-03-2015 05:49 PM
