My o5 RL continues to have a tire presssure warning for the rear tires. I add air and it goes away, yet comes back in a couple of days. Has anyone experienced this?
LIST/RAMEN/WING MAHSTA 짱
princelybug
close
- Join DateAug 2007
- LocationOrange, CA
iTrader Positive Feedback100
iTrader Feedback Score(16)
Liked:210 Times in 161 Posts
Hey Hammock, just in case, why not check the tire pressure manually? If the psi is good, than you might have to take it to the stealership.
Sounds to me like a case of TPMS telling you to get that slow leak fixed. Have you inspected the tread for screws or nails?
I had the same problem with my MDX. One of the valve mechanisms was loose inside the stem. Once I figured it out, took all of ten seconds to fix. Just need the right wrench.
LL
LL
Quote:
ha.. reminds me of my problem.. every so often the low fuel light comes on -- I put gas in and it goes away.. but it aways comes back after a week or so.. Originally Posted by hammock
Hd the same problem with my low fuel light. I finally started topping off the tank every 25 miles or so. Problem solved!
LL
LL
