Spare tire size for ones with aftermarket rims
Cruising in ATL!!
For those with aftermarket rims installed on their 2G RLs... what size of spare can you fit? I have 19's (ronjons) on mine and was curious if I have to look for specific spare size that would work with these 19's.
Thanks in advance.
Thanks in advance.
The RonJon setup should be awfully close the OEM setup from an overall wheel/tire diameter standpoint. That being the case, I wouldn't imagine there would be an issue with the OE spare.
Maintain the same rolling diameter for the spare tire as the tires that you are using. That being said, a stock spare from a 2005-2008 non-PAX RL should be OK, assuming you stick to 245/40-19 tires on your Ron Jons.
You will need to get 5 new lug nuts because your PAX lugs won't fit, and depending on what lugs Ron Jon uses. If he goes with standard 60 degree acorn seats, those won't fit the 2005-2008 spares either. If you come across a 2009+ RL spare, those wheels should actually be able to take the ball (spherical) seat lugs that the the PAX wheels use).
Cruising in ATL!!
I see you have 2006 RL Tech Pkg that was originally equipped with Michelin PAX wheels and tires.
Do not have PAX lugs on my ronjons now. So looks like i need to start looking for OE spare. Any good place to get it besides dealer? Don't see much on ebay.
The time honored spare tire parts list from this forum for 2006-2008 PAX equipped cars is:
* Trunk Spacer Assembly (Part number: 84542-SJA-A00) - a styrofoam insert
* Adapter - Spare Tire (74651-S2x-003) - a bracket to hold the tire to the floor
* Bolt - Spare Tire (74652-SDA-003 - a long bolt to tie the bracket to the floor
* Label - Spare Tire Adapter - Not really needed but cheap (74653-SJA-003)
* Nut - Wheel (90304-SHJ-A91) - Need 20 of them or 16 and a set of wheel locks [OPTIONAL DEPENDING ON YOUR SOLUTION...you may only need 5, or none depending on your situation and the spare wheel you end up getting]
* Disk Aluminum Wheel (this is the spare wheel that uses the nuts above) - 17x4T (42700-SJA-J51)
* You will need a valve to hold air and to use for inflation/deflation
*Spare Tire T155/70D17 - this has been a hard item to obtain, back in 2008, only Firestone and Goodyear made them, don't know about now.
nuldabz
09-03-2015 05:49 PM
