Some pictures of my RL with the new Elbrus 102 wheels
I took these with my phone this morning, so please excuse the poor quality.
I am very happy with this set. Wheels are Elbrus 102 and tires are Continental ExtremeContact DWS size 245/45/18. Car has stock suspension. http://www.danail.org/Acura/IMG00123.jpg http://www.danail.org/Acura/IMG00122.jpg http://www.danail.org/Acura/IMG00121.jpg http://www.danail.org/Acura/IMG00120.jpg http://www.danail.org/Acura/IMG00119.jpg |
Looks good! How do you like the Continental tires compared to the Pilot HX MXM 4 tires?
Originally Posted by B Feelgood
(Post 11385744)
Nice wheels! Can you post your wheel specs? width and offset? thanks!
Originally Posted by huck-jai
(Post 11415235)
They are about 26lbs/each Wheels fit flush with the fenders. Very nice fit! |
Look nice. I am looking to put the same on mine. Did the nice fit with 42mm offset mean they didn't have to use spacers? Where did you buy them/have installed. I am in the same area and looking to do the same but will probably go with Michelin Pilot Sport A/S Plus's or perhaps Bridgestone Tourenza.
- Joe. |
Pretty good pictures for a phone. What did you use?:thumbsup:
Originally Posted by Chas2
(Post 11428595)
any thoughts / concerns with 255/35-20 or 255/40-19?
Immdeiate thoughts without doing the research, I would check to see that the rolling diameter is as close as possible to the stock size to prevent speedo and odo errors. The same speed data is fed to computers in the car for various systems from engine management, to VSA to ABS to SHAWD and I am sure others, assume a 26.7 inch diameter tire in their programming. I think accepted tolerances are plus minus 2%, or at least that is what I have been using as a rule of thumb for years, though I try to stick with plus minus 1% if at all possible. Use the 1010 Tire calculator as a quick and dirty. Check the option box to give you a listing of all tires in those sizes. It is not everything, but a gives you a good idea of the majority of the tires out there.
I would also check your wheel width. The design guidelines for low profile tires 50% aspect ratio and shorter are less forgiving, and if I recall, 255 section width needs a minimum of 8.5 inch. |
Just got my tracking number today.I am getting same rims and tires as you except I went with 245/40/18 for my TL.They look great.
