Show us your aftermarket and OEM wheels on your RL
Old 07-16-2017, 06:06 PM
  #441
teh CL's Avatar
That's not too bad. We should set something up before summers over
Old 07-19-2017, 02:33 PM
  #442
deepa1600's Avatar
Sure, however I am working on the issues i have with the car. I bought it about a month ago for 4800$ taxes in, it had 165k. I had to fix a lot of things: brakes, new tires+used rims, had rust on left side roof near A-pillar and it's still leaking when it rains hard. Seats are ripped, left headlight flickers (ordered used ballast+igniter for 110$ from ebay) and faded (gonna use sylvania headlight kit). Good thing is i do all the work other than body stuff. Other than cosmetic stuff it is, mechanically, really good. Do you know anyone who can fix seats? I have attached pictures below. Driver's side
Passenger side
Driver's Seat
Driver's back
Passenger seat
Old 07-21-2017, 10:39 AM
  #443
teh CL's Avatar
Perks of the high mileage RL club..
I was quoted $700 to fix both my seat bottoms & armrest from a local shop. Haven't bit that bullet yet though..
She looks good though & you lucked out with an Aspec
Old 11-29-2017, 01:42 AM
  #444
fuzzysig's Avatar
The following 2 users liked this post by fuzzysig:
projektvertx (12-27-2017), wilspainar (06-12-2019)
Old 12-27-2017, 02:47 PM
  #445
fuzzysig's Avatar
and the racecar set
Old 01-13-2018, 11:10 AM
  #446
Da ReaL BiGGMaN's Avatar
Those 19" RonJon Legends are BOSS!! How much are thosE??
Old 04-16-2018, 03:34 PM
  #447
KB1
KB1's Avatar
19"Connoisseur Original Designs by Yokahama
245 40 19 8.5 x45 offset Bridgestone Adrenalin RE002
Just tossed them on... can't believe how much freezing rain we got up here in Ontario though .. took off my nokian hakkapeliitta's a few days early .. just couldn't wait 😂
The following 2 users liked this post by KB1:
projektvertx (04-21-2018), teh CL (04-19-2018)
Old 04-20-2018, 09:20 PM
  #448
HDNBenjamin's Avatar
looks good..just a bit of a drop and a spec kit and it would be perfect.
Old 04-23-2018, 07:58 AM
  #449
3rd Gear
g2096's Avatar
The following 3 users liked this post by g2096:
Shadow2056 (05-31-2018), teh CL (05-01-2018), tkosho24v (08-03-2018)
Old 04-23-2018, 08:18 AM
  #450
3rd Gear
g2096's Avatar
The following 4 users liked this post by g2096:
MSW 6SP (04-23-2018), Shadow2056 (05-31-2018), teh CL (05-01-2018), tkosho24v (08-03-2018)
Old 07-04-2018, 09:22 PM
  #451
kcjohnnyboy's Avatar
Here are my photos of my 19" VMR wheels. Thanks to Tracy from VMR wheels for the excellent help from getting the specs to my liking and his suggestions. Well recommended from this satisfied customer. And, finally after almost 2 years after I purchased these wheels, I get the time from my busy schedule to finally mount them onto my RL. I am already lowered on H&R lowering springs so the ride height is not stock, which soon will be switched out for my Largus full body coilovers. Enjoy!
Old 07-11-2018, 10:31 AM
  #452
tkosho24v's Avatar
This is my new setup. This wheel size and offset places emphasis on function and form rather than trying to fit the widest wheels with the least offset / read: Adult Built!
The fenders are not rolled and they do not rub. No compromises in handling and the steering feel is as close to OEM as intended. Full M1 body kit in the painters. Stay tuned.
BBS LM 19x8.5 +32 w/ 245/40-19 Advan db
Old 07-11-2018, 10:46 AM
  #453
tkosho24v's Avatar
For comparison, this old set up with 19x9.5 +25 needed massive fender work in order to run without rubbing. The looks are sublime but in all honestly my new set up above corners as if on rails and I would never trade my new for the old..... As you can see below, I have been there done that. So it all depends upon taste.
Old 07-11-2018, 11:11 PM
  #454
pewpew's Avatar
The new setup is clean! Do you happen to have a head on shot or a more frontal view? I have some 19x8.5 +35 and want to get an idea of how it sits in relation to the fender. Planning on running a 245/40 as well.
Old 07-14-2018, 03:31 AM
  #455
4th Gear
K23menor's Avatar
I have a 07 acura rl i wanna know whats better 19s or 20s and what should i have on springs to lower it 1.3 in the front or 1.2 ?
Old 07-22-2018, 11:39 PM
  #456
BBS is definitely one of my favorite rims!
tkosho24v (07-24-2018)
Old 07-24-2018, 06:51 PM
  #457
tkosho24v's Avatar
pewpew (07-27-2018)
Old 07-24-2018, 09:45 PM
  #458
4th Gear
K23menor's Avatar
Super clean bro then paint and lights 👌🏼are those aftermarket fog lights ? Also is drop i can't see your rims
Old 07-25-2018, 02:39 AM
  #459
4th Gear
AyoThatzDBo's Avatar
man, am i glad i decided to check this thread out. currently in the market for the RL. this wouldve saved me so much headaches for wheel fitments. currently drive a static 6th gen accord, any ideas on what specs to achieve the same or similar look as it? my current wheel specs are 18x9.5 +22 with 215/35 squared
Old 07-26-2018, 07:15 AM
  #460
tkosho24v's Avatar
The largest problems you will face with a KB1 is that it is a 120 PCD pitch and that you need lots of front caliper clearance. The second obstacle is that the thing is a heavy car. The weight rating is a safety issue that should not be ignored. Also this being a AWD set up, a square fitment is a no brainer.... some have successfully made off with 225/35-19 and 255/30-19 and kept the diameter as close to F/R as possible. No longer wheel studs are available in a M14x1.5 as I know of so the saga is this. Test fit the wheels and see if the calipers clear ...... This is a helpful site.
https://www.willtheyfit.com/index.ph...et2=20#content
Anything over 9.5J width with +30 or less will not work unless you are willing to stretch tires and utilize natural camber to tuck....... best of luck.
Old 07-27-2018, 12:51 AM
  #461
pewpew's Avatar
Originally Posted by tkosho24v
I appreciate the pictures! exactly what I needed to see. I currently have a 19x8.5 +35/22 set and was maybe hoping it was slightly more aggressive up front. I avoid spacers if possible. I guess I can try and source another +22 pair but 19" SSR Type F in 5x120 is nearly impossible lol
Old 08-10-2018, 10:26 PM
  #462
8th Gear
sean06RL's Avatar
Advanti N931 wheels 19x8.5 with 35mm offset or 40mm cant remember
tires- 245/40/19
Old 11-05-2018, 02:25 AM
  #463
Lowpass's Avatar
Hi,
Nice thread, beutiful Legends/RLs.
I'm running Dezent TX wheels today 18x8 ET45 with a 235/45-18 Goodyear Eagle F1.
Really want to try something bigger now.
Do you think that a 20x9 wheel with ET38 will fit in the wheel wells of the Legend/RL? (Exclude the caliper for now, I know the issues with it)
With this I am thinking a 255/30-20 or likely. Please input.
Also considering a drop with this setup. Probably H&R springs.
Does anyone use camber adjustments in the front or is the camber ok with the HR drop?
Also saw that some of you run 20x10 with some rolling of fenders. Thats crazy wide! Looks awesome.
Hope someone can answer some of my questions,
Thanks in advance
Old 11-23-2018, 04:14 AM
  #464
Lowpass's Avatar
Originally Posted by 1CLNRL
New Shoes
20x9 +35 Niche Ritz
245/35-20 Falken Tires
Did you need any modification on fenders to make this fit?
I'm thinking 255/35-20 with same ET. You think it works?
Old 11-23-2018, 11:14 AM
  #465
MSW 6SP's Avatar
Work Gnosis GS1
Old 03-03-2019, 08:30 PM
  #466
waltthizzney's Avatar
Will 2010-12 OEM RL wheels fit perfectly on the 2005-2009 RLs? Or do I need a spacer?
Old 03-27-2019, 04:43 PM
  #467
RG08RL's Avatar
I have the A-spec wheels on my 2008 RL, Has anyone experienced chrome flaking or peeling off rims? I went to two local repair wheel shops and they can't do chrome, only powder coating which at $600 for all 4 wheels is kind of tempting. Any luck with powder coating the A-spec wheels? Pictures?
Old 03-29-2019, 10:38 AM
  #468
Ricky Gutierrez's Avatar
Motegi MR137’s
18’
Leo2526 (12-30-2019)
Old 05-04-2019, 09:36 PM
  #469
deepa1600's Avatar
Today washed and waxed. FAST FC04 Bronze(19x8.5, 45 ET), 255 40 19 Michelin pilot super sport.
The following 2 users liked this post by deepa1600:
altair47 (04-15-2023), Leo2526 (12-30-2019)
Old 07-27-2019, 03:27 PM
  #470
5th Gear
Apodalont's Avatar
Originally Posted by 253RL
Well since there is 0 interest in my wheels I figured id buy more tires and put them on for kics so here goes;
Attachment 49922
Attachment 49923
Attachment 49924
Attachment 49925
In my personal opinion, those wheels in that exact size and with your cars exact ride height are spot on perfect. Those have to be the nicest and best looking aftermarket wheels I've ever seen on the 2nd gen RL!! Beautiful car my friend!
Old 10-18-2019, 06:28 AM
  #471
leonard dillon's Avatar
Acura tl 19's
[QUOTE=Zelaya;12678982]19's in the best way to go
Attachment 52949[/QUOT
I'm tryna put these TL 19's (on left) on my 06 RL How can I do it I need help anyone please? The front rim was hitting the brake caliper!
Old 10-19-2019, 05:14 AM
  #472
5th Gear
Apodalont's Avatar
Soo clean!!
Attachment 49922
Attachment 49923
Attachment 49924
Attachment 49925
This set up is so so so damn clean! Every time I come across pics of this combo I just stop and admire it while probably drooling a bit!
Old 12-10-2019, 05:04 PM
  #473
3rd Gear
Arkadiusz Tyszecki's Avatar
hi,
have you type of your wheels excacly?
Old 12-30-2019, 12:17 PM
  #474
6th Gear
Leo2526's Avatar
I need opinions, i am thinking of 335 wheels 17x8 +34 any ideas of clearing the calipers?
Old 12-30-2019, 12:29 PM
  #475
6th Gear
Leo2526's Avatar
same thing is happening to my stock wheels. Its anywhere between $400+ to powder coat which makes me just shop for other wheels
Old 05-08-2020, 03:08 PM
  #476
Karlos Garcia's Avatar
Old 05-31-2020, 11:42 AM
  #477
Dee Alado's Avatar
Rims
Originally Posted by KB1Spec
My wheels. Same as Zelaya but 1 inch bigger. =P
Attachment 52899
Attachment 52900
what is the size and company? How did you get them to fit?
Old 05-31-2020, 12:45 PM
  #478
DCenti Racing
20" 245 35 r20
I dint have to change absolutely anything
I will put more pics
Old 04-09-2023, 05:43 PM
  #479
Chalkjr's Avatar
07 MDX wheels, 19 x 8.5 +45 with 245/40/19 tires. Paired with 10mm spacers and extended studs on Tein coilovers.
projektvertx (04-09-2023)
Old 06-09-2023, 11:24 AM
  #480
9th Gear
Coolio515's Avatar
Enkei Ekm3 18x8 wrapped in Riken Raptor 245/45/18 and lowered on h&r sport springs. Perfect daily setup
Quick Reply: Show us your aftermarket and OEM wheels on your RL
