Run Flat Question
Run Flat Question
I can't seem to find this after a few searches, but can you replace the run flat tires with standard tires? How will this impact the Tire pressure sensors? I've read some threads that touched on the design of these wheels, which impact the removal of the tires..... Also, how much do the PAX tires go for each? thanks
Q: How do car dealers service PAX System?
A: Car dealers normally only replace complete PAX System units, meaning they will take a flat tire-wheel assembly off and put a new PAX System on a vehicle. In some cases, the vehicle dealer may also be an authorized PAX System servicing location and will be able to perform repairs or replacements. For complete information on what constitutes a warranty replacement, please see the warranty for details. Furthermore, please see the following question to address when a consumer is responsible for purchasing an entire PAX System assembly versus simply replacing the tire.
Q: What's the cost to replace a PAX System tire?
A: A replacement PAX System tire retails for approximately 10% to 15% more than the price of the comparable traditional Michelin tire.
Q: Do I need to replace the entire wheel each time I need new tires?
A: No. PAX System tires that are worn out are replaced just like traditional tires. However, these tires should only be replaced at a Michelin-authorized servicing dealer with the appropriate PAX System-capable mounting/demounting equipment.
http://www.michelinman.com/differenc...ystem_faq.html
Originally Posted by synth19
^ geez.... but why can't you just replace them for traditional tires if you so choose? Very informative post.
You will absolutely need new rims. PAX rims are not only metric, but are constructed differently so a deflated PAX will not separate from the rim like a standard tire.
Similarly, a standard tire will not fit on the PAX rims.
If you do switch out PAX rims, I do not know what happens with the TPMS, and I know for sure, there is no spare.
TLDude876
12-28-2016 03:18 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
