PSI for 19" tires
PSI for 19" tires
Hi, I just my put summer set up on my RL, 19" wheels with 255/40/19 tires and want to know what PSI work best for 19" tires? For now ( 1-st day)I have 35 PSI and I think I can go little higher, 37-38 PSI ? Tx.
I've been running 35lbs all around. Other suggestions would be helpful to me too.
I understand from RonJon that the OEM 17s weight somewhere around 26-27 lbs. Can someone else verify this? I should be able to find out my self in the next few days...
L8r,
L8r,
Originally Posted by slawek65
You know what, I did weight BBS before I install tires and BBS weight 19 lb each, but I don't know how much OEM wheel weight.
The total weight of the oem combo is 52 lb (rim and tire) according to a RL magazine article I have and the tire is listed to weigh 26 lb, so yep the rim should also be ~26 lb.
Originally Posted by Touge
Treblig you want some difference front to back as the RL is a nose heavy car. It'll help reduce some understeer.
5Zigen Acura RL
The ride gets stiffer, but other than that you should be ok. I always like to but a bit more when I get low profile tires and big rims. It helps protect the lip from bending incase you hit a big pothole.
Thank You 2005RL.I think my RL is lakeshore silver,it's meteor silver same color or just the name ??? Now I am shopping for body kit. Mugen it's my choice but shipping from Japan it's
If I can find good price for shipping I am ready to go for it.BTW my 2-nd choice it's Amuse.
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
NBP_BALLER
09-23-2015 08:18 PM
CostcoFanAUS
09-18-2015 06:05 AM
