one front wheel stud broke
So my mechanic said if he changes it, he recommends to order a wheel bearing because it will get damaged. Any one know why??? Is he doing it correctly?
The tech is correct because in order to take out the stud the hub must be pulled out to pull the stud out. A slide hammer will be used to remove the hub and there is a 50/50 chance the bearings will fall apart. just corss your fingers!
nuldabz
09-03-2015 05:49 PM
mtl_ilx
09-03-2015 09:48 AM
