Info on these wheels
Hi all,
Im based in Australia, so my car is a 2006 Honda Legend KB1, I want to put some after market wheels on it and have decided to go for 18” over bigger wheels to keep as much ride comfort as possible and the cost of replacement rubber.
my question is would the wheels that I’ve attached fit my car without rubbing or need to roll fenders and etc. they have a quite aggressive offset of +22. Will they fit without a hitch and if not what offset (range)
should I be looking at that will.
I would test fit to make sure they clear front calipers and suspension. In the back they will most likely rub so you would need to roll the fenders. I had 19x8.5 wheels with 30 offset and 245 40 tires, the tires would slightly touch the fenders when going over bumps under load.
imagerockone
01-07-2007 12:50 PM
