Front Strut Recommendations
Old 07-11-2017, 12:14 AM
alfadoctor's Avatar
I have a clunk sound coming out of the LF strut. I suspect it is a bad strut with 210,000 on it. Rather than just do fronts and later the rears, I am going to do all 4 at once and be done with it. I noticed an oil spot on the RR shock.
What are your recommendations and how do they compare to stock?
I will have a local shop install the fronts and do a re-alignment.
Old 07-11-2017, 06:26 AM
Received 16,260 Likes on 11,971 Posts
Go OEM.
Old 07-11-2017, 06:37 AM
projektvertx's Avatar
You have OEM or KYB. +1, My vote is OEM.
Old 07-11-2017, 09:02 AM
teh CL's Avatar
/thread.
Old 07-11-2017, 02:02 PM
phishfood's Avatar
OEM
First one lasted 200k why change
Old 07-11-2017, 02:51 PM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
Another thing you might want to check is the swaybar end links.
alfadoctor (07-12-2017)
Old 07-12-2017, 09:43 AM
alfadoctor's Avatar
Thank you all for the comments.
There isn't like a dozen options out there as it really comes down to 3...OEM, KYB and Gabriel.
I can get KYB at a great price and I have had them on a couple of other cars. As to the front end noise, Of course, as we know new struts means new upper strut bearings and covers.
I will check the end links, great suggestion. I am wondering if it a lower ball joint as my 97 RL had that issue around the same mileage.
Old 07-12-2017, 09:54 AM
the thing is; aftermarket doesnt nearly put as much R&D into their products as OEM.
if you're fine with going for less initial cost up front, then head to the aftermarket, like KYB
Old 07-12-2017, 03:08 PM
HDNBenjamin's Avatar
definitely OEM if you plan on driving it for another 100k. will you replace the rears too?
Old 07-19-2017, 09:37 PM
davenga6535's Avatar
how much should I pay a dealer to replace struts and shocks on 2007 acura rl
Old 07-20-2017, 08:27 AM
When I bought OEM struts it was a 700$ bill using online Acura vendors that offered significant discounts over actual dealer sticker price. It honestly wouldn't surprise me to hear 2000$ including parts and labor at an Acura dealer.
Old 07-21-2017, 05:37 PM
deepdezal's Avatar
has anyone heard for 'SACHS' struts? rockauto has then, but they are out of stock.
deepdezal
Old 07-23-2017, 08:54 PM
Sounds like they "sach" too much. Pardon the attempt at the pun
Old 08-02-2017, 08:49 AM
pcloadletter's Avatar
ZF Sachs is the OEM supplier for the RLX struts.
