Extended wheel studs solution
I recently ran into a problem with my kb1 have noticed a lot of people had problems with this too wheel fitment I have to get wider spacers for my car to fit my wheels but also needed extended wheel studs which where are very hard to find I found that if you use dorman 610-471 u should b good
Dorman 610-471
knurl diameter = 16.38mm =.645in
Shoulder = .435in
total length 67mm
Threads 9/16"-18
the only thing you would have to change would be the thread size so meaning you would have to change your lug nuts to 9/16-18 and after that you'll be fine
Stock wheel studs 610-527
Knurl Diameter:0.6495
Shoulder Length (in):0.427
Thread Size:M14-1.50
Length 1.7912
I had to do a lot of research but I found another option so there u guys goo extended studs on their Acura RL generation 2 i have pics but dont know how to post pics
Specs nd photos thread
https://acurazine.com/forums/4g-tl-tires-wheels-suspension-298/wheel-spacers-5x120-916260/
https://acurazine.com/forums/2g-rl-tires-wheels-suspension-92/wheel-spacers-rl-here-deal-919379/
Dorman 610-471
Shoulder = .435in
total length 67mm
Threads 9/16"-18
Length 1.7912
