Coilovers suspension specs (largus)
Old 10-27-2016, 04:38 PM
Geezey617's Avatar
Hi im new to this.. I just bought suspension from Acura RL largus I'm trying to figure out ride height and spring compression ratio (to ride smooth nd stiff) basically the measurements ? For any coilovers too ( pre load ?) Wat ur suspension spec thats good
Old 10-27-2016, 04:46 PM
Received 8,583 Likes on 6,630 Posts
So... you bought suspension but unsure of the specs?
Your post is very hard to decipher. "What's good" when it comes to ride height and dampening is 100% personal to what your goals are. Watch this video and see what works for you:
teh CL (10-27-2016)
Old 10-27-2016, 05:35 PM
Geezey617's Avatar
Your post is very hard to decipher. "What's good" when it comes to ride height and dampening is 100% personal to what your goals are. Watch this video and see what works for you: https://www.youtube.com/watch?v=xmr14nCivZA
I kno how it works i jus want to kno da rear measurements so I don't have to do trial and error because you have to take apart the whole rear suspension to adjust the rear
Old 10-27-2016, 05:37 PM
Geezey617's Avatar
The rear measurements for somebody that's riding low? So I can have a base to work off of
Old 10-27-2016, 08:19 PM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
Hi, welcome to the forum. You will find above the main forum 4 sub-forums with special themes targeting certain areas of the car. Please wander into the suspension forum and see if you can find you answer there. There are at least two members on Largus coilovers. If you find them, you can send them a PM or bump their thread to speed up your search of an answer.
What is probably most helpful is the "search this forum" toolbar just to the top-right of all forum pages. That is the most direct route to search the forum you are in along with its sub-forums.
You can try to create a new thread (as long as it's not a duplicate) and hope one of the two members randomly appears to give you your answer, or you could help yourself by digging around in the plethora of information here. Either choice is fine. It's up to you.
Old 10-27-2016, 08:21 PM
teh CL's Avatar
Setting up suspension is ALL trial and error, there's really no way around it.
As for preload, I always went with keeping the spring snug so it doesn't budge at all. Coils should have come with instructions as well.
Old 03-23-2018, 05:11 AM
Kb1_RL's Avatar
where did you buy your largess setup at?
Old 06-12-2019, 10:09 PM
kcjohnnyboy's Avatar
I know when I bought my set, I found them on eBay
quanaman
10-27-2016 03:23 PM
Christina Hines
ILX Tires, Wheels & Suspension
08-03-2016 07:30 PM
Quick Reply: Coilovers suspension specs (largus)
