20x8.5 40+ fit?
Old 05-22-2017, 06:55 PM
JohnDillinger's Avatar
20x8.5 40+ fit?
I have a set 18x8 40+ on my rl but enkei can't be sure these wheels would fit. Anyone here know any better? They want 20% restock if they dont fit
Old 05-25-2017, 10:42 AM
6th Gear
zee32tl55's Avatar
I have the exact specs with Asanti Wheels. I would try to test fit with a local dealer. Then order from other place.
Old 05-25-2017, 10:48 AM
Navyman72's Avatar
Go to a rim shop and they should have a tester rim that you can fit to see first.
Old 05-25-2017, 05:10 PM
NathanJax's Avatar
It's not about the backspacing. It's about the clearance between the spokes and the front brakes. I agree you need to test fit. I ordered a different wheel than what I have now, EXACT same specs, however, the spokes hit my calipers so I would have had to run a spacer.
Old 05-27-2017, 07:45 PM
deepa1600's Avatar
Hi Guys, I know that front barkes on our car are big. My question is what is the widest 18" wheel/tire (eg 265/40/18 on 8.5" or 9" rim) you can put without rubbing or rolling fenders?
Old 05-28-2017, 07:44 AM
MSW 6SP's Avatar
We can't give you an answer without knowing the offset as well.
Old 05-28-2017, 09:40 AM
teh CL's Avatar
Old 05-29-2017, 02:20 PM
deepa1600's Avatar
Originally Posted by msw 6sp
we can't give you an answer without knowing the offset as well.
et:35+
