2009 Acura TL Rims - Don't Fit!
Old 07-10-2009, 12:47 AM
  #41
gbriank's Avatar
Originally Posted by deaddawg
The tires are Yokohama S.Drive 245/40R19. I don't have a scale, but I will try to weigh them somehow before they are on the car.
Ooooh, good tire choice! I keep hearing stories about great aftermarket rims being paired with some awful no name brand tires. Totally ruins the whole reason for the new rims (ahem....KICK BUTT TIRES).
Old 07-10-2009, 11:34 AM
  #42
Chas2's Avatar
Originally Posted by 07RL= Real Luxury
take 2!
Let me know what you guys think?
BTW anyone got the hook ups on the Mugen Lip??? holla. Thanks my Acura FAM! Peace.
As usual, I would call the manufacturer to check fitment and work with your retailer to get a fitment guarantee so that you can return them in the event they do not fit. The RL is a difficult fit. Make sure the wheels are TPMS compatible (probably want them pre installed if you are buying a set of wheels/tires from the same place, have hubcentric fit (probably comes with a ring), and check on the lug seats, because you will probably not be able to use the flat seat OEM lugs. Hopefully they would also supply lugs for you.
Know the RL stock specs so you can speak intelligently with them and detect BS.
I would also check on the weight as 20's can get awfully heavy.
Old 07-15-2009, 09:07 PM
  #43
7th Gear
07RL= Real Luxury's Avatar
they look, fit and ride nice!! = )
Chase 2 here are the pics. do you know anyone who can get the Mugun front lip for the 05-08 RL's?? BTW I hope these pics of my car post up, not sure why people can not view them. Thanks!
Old 07-15-2009, 09:41 PM
  #44
Chas2's Avatar
For whatever reason, cannot see the pics
Old 07-16-2009, 12:59 AM
  #45
2013 RL or bust
afjock21's Avatar
What's the deal with those pics of the TL wheels on the RL? You ever finish or what?
Old 08-03-2009, 11:48 AM
  #46
deaddawg's Avatar
Yeah, I finished a while ago, been too busy with work nowadays!
A quick search and I found this pic of it, not the best to show tires but at least it is something.
Old 08-04-2009, 11:08 AM
  #47
nyjohnchan's Avatar
Deaddawg, do you have photos for your spacers, and where did you get them from? Thanks
Old 08-05-2009, 10:07 PM
  #48
deaddawg's Avatar
Forgot the pictures, but they are just bolt-on spacers like anything else.
As for where I got them, https://acurazine.com/forums/showpos...8&postcount=16
Old 08-08-2009, 08:37 AM
  #49
nyjohnchan's Avatar
I just spoke with a tech from an acura dealer. He had tried to put a 09 TL rim on a 06 RL. He said it needs 10mm spacer to clear the brake.
Old 08-08-2009, 11:40 AM
  #50
deaddawg's Avatar
Yeah, 19mm is more than I needed, but in order to get bolt-on spacers I had to go 19mm.
I do like how the wheels are pushed out more though.
Old 08-11-2009, 05:41 PM
  #51
3rd Gear
wal7sh's Avatar
Kool6123,
With the 12mm spacer were you able to screw on to the stock bolts? Or did you have to extend your bolts coming out of your hub?
Old 03-17-2010, 08:27 AM
  #52
nyjohnchan's Avatar
7mm spacers
I put 6.5mm washers on the bolts and it clears the brakes. So I ordered 7mm spacers from motorsport-tech. Will update once they come in. By the way, I can turn the nuts 6 times after I put on the washers. Is it safe enough?
Old 03-17-2010, 07:59 PM
  #53
Chas2's Avatar
Good question. How many times could you turn the nuts with the stock wheels to about 90 lb-ft, and you will have your answer.
Gut feel is you are on the edge, but I do not know.
And assuming the lug nut seats are the same as on the, right? Earlier (2005-2008) non PAX used flat seat or while 2009 and later use a ball (spherical) seat. Not clear to me what the TL uses. I thought I recalled reading the 4G TL uses a ball seat.
Let us know what you find out with the lug turns.
Old 03-28-2010, 07:00 PM
  #54
deaddawg's Avatar
As an update, lots of better pictures of these Rims and tires in this thread:
https://acurazine.com/forums/2g-rl-tires-wheels-suspension-92/rotora-rotors-ebc-pads-tl-rims-looks-good-768864/
Old 04-06-2010, 10:16 PM
  #55
nyjohnchan's Avatar
Just installed the 09 TL black chrome wheels on my RL. I used 7mm spacers in front only. It clears the brakes by 1mm(very close) Spacers were ordered from Motor-tech for $45 each, with shipping total $115.
Old 04-06-2010, 10:18 PM
  #56
nyjohnchan's Avatar
Dont know how to post pictures, I can send it to someone who knows how. Anyone? Thanks
rseb4agze
05-03-2016 07:41 AM
lland
10-04-2015 04:47 PM
iesu3423
09-29-2015 08:04 AM
nuldabz
09-03-2015 05:49 PM
bailey24
08-31-2015 05:38 PM
Quick Reply: 2009 Acura TL Rims - Don't Fit!
