JDM KB1 LEGEND in Japan.... build thread.
13 Attachment(s)
Well, here goes... I had lived in California and also built numerous Acuras but moved to Japan... This is the latest incarnation.
2007 JDM KB1 with Mugen aero and M1 flares. Largus Fulltap Harmonics TSW Stowe 19x9.5 ET20 with 245/35/19s. Though mine is a clone.. this is the catalog rendition of the 100 limited edition M1 offered as a new dealer option in Japan. Attachment 47098 so, here is the image of how I purchased this car... Attachment 47099 I decided on a reasonable build budget that was not going to kill me... here are the parts selected for this project. Attachment 47100 Attachment 47101 Attachment 47102 Functionality was to remain intact. I wanted this to be something that can be driven daily....:thumbsup: So off we go to have the stuff installed... Attachment 47103 After some final ride height adjustments, here we are... Attachment 47104 Attachment 47105 Attachment 47106 Attachment 47107 Attachment 47108 Attachment 47109 Attachment 47110 |
Off to a great start! What is your plan for the exhaust? You should get the aero kit and flares molded.
:thumbsup:
mufflers and exhaust.... hmmmm.
2 Attachment(s)
Originally Posted by MSW 6SP
(Post 15157170)
Listen at the 2 minute mark...this car sounds mad!:thumbsup:. Attachment 47096 Attachment 47097 |
At :06 seconds. Maybe the driver could have stopped for those people crossing the street.
Originally Posted by Mike734
(Post 15157318)
Yesssss the build thread is up. Good shit TK, shit is about to get real.
Sounds like straight pipe. Tips look stock. Sounds good but I bet it drones like a mofo. Do you have anymore info? I'm planning on adding super 10 mufflers and delete two rear resonators. Kinda like this tl. Acura TL Flowmaster Super 10:
Looks like the kb2 is straight pipe to MagnaFlow rears.
Magnaflow rears only..: |
Holy crap! that UA6 is off the hook.... it must drone like a buzz bomb as well.... That KB2 is, well for a lack of a better term.... acceptably loud in my opinion... I like it.. and with the catalizer in place, should be rounder in tone and have less of a bite than his set up...
this is the tone I am after....
Looks good!
What did you do with that Honda Grill? |
Originally Posted by Nersh7
(Post 15157843)
Looks good!
what brand coilovers are those?
Originally Posted by kcjohnnyboy
(Post 15161750)
What's a tap body?
K&N Typhoon Short Ram Installed.
3 Attachment(s)
This is a K&N Typhoon Short Ram designed for a Honda Accord CP3. The modification obviously required was adapting a block off plate for Air Mass sensor, which the KB1 does not use... I also rerouted the throttle body coolant line and rear cylinder bank PCV hose with the one supplied in the kit.... Great sounds as it hits final stage VTEC. Listen to the video and turn the volume up!!!
Attachment 47088 Attachment 47089 Attachment 47090 |
fulltap explained...
Originally Posted by 253RL
(Post 15162000)
What's a tap body?
Good stuff man. :thumbsup:
Greddy Touch Display Installed
7 Attachment(s)
I am a sucker for information displays and I was hooked when I first saw one of these....
Attachment 47081 So, I sat around wondering how I was going to be able to get a oil temperature and pressure display in a compound unit and the Touch was the answer... To hell with a half dozen 70mm Defi displays in the dash of a KB1.... ghetto is just that. Ghetto. Attachment 47082 This is what the maker claims on this product. The Intelligent Infometer Touch is the latest from Greddy's line of information display products. The latest release features the highest quality 3.5" TFT screen from any of the meters, combined with flexible layout, installation and connection. 3.5" 65,546 Color TFT Screen capable of displaying up to 6 signals at once Completely touch screen, configured by simply touching the screen Can be installed in 3 different layouts Connects to ISO14230 connector Connects to old Nissan CONSULT with additional harness Connects to the latest CAN connector Can display from 53 signals, see the Greddy website for more details 15min signal record playback with warning and peak hold Displays in Metric or SEA options Displays in English or Japanese This unit fits well in the slot above the ashtray and is held in place by hook and loop strips. Attachment 47083 Attachment 47084 Attachment 47085 It looks trick at night as well.... Attachment 47086 Just to stray on the dark side of overkill, I tossed in this trick rear view mirror that has a built in flash memory of all know speed cameras and speed traps and uses GPS technology to alert as well as to display velocity. Attachment 47087 |
Went for a cruise into Tokyo...
3 Attachment(s)
So freaking Japanese... God help me...:ugh:
Famous Roppongi Crossing. Attachment 47078 Tokyo Tower shot. Attachment 47079 Asakusa Shrine Entrance.... Attachment 47080 |
so when you move on to something else let me know!! I'll import this thing back to the states and can die a happy man!
That's sweet! Can you shed some more light on what was involved in the install?
Also you have PM |
Awesome very good information on the coils.
Good stuff.
But you need re-alignment for "RL" emblem. Not on where should it be. |
^^ What? If you're talking about the video; A: I don't think that's his car, B: The RL logo is in the right spot the Acura logo was put on too high up.
Originally Posted by tkosho24v
(Post 15157496)
Legend KB1 ãƒ¬ã‚¸ã‚§ãƒ³ãƒ‰ã€€ãƒ¯ãƒ³ã‚ªãƒ•ãƒžãƒ•ãƒ©ãƒ¼ã€€æŽ’æ° —音 - YouTube |
install8ion of Touch....
2 Attachment(s)
[QUOTE=Nersh7;15162757]That's sweet! Can you shed some more light on what was involved in the install?
Simple... plug into OBD II port, run hot switched, initialize the unit, DONE! As for the planned Oil Pressure and Temperature, I will run a interface that is available from Greddy and 2 sensors with a oil filter plate with twin NTP fittings.. Attachment 47076 The adapter plate should look like this.... Attachment 47077 Also, the unit acts as a Fault Code Scanner and Reset Tool....:thumbsup: |
Mugen Rear Deck Spoiler Installed with Roof Spoiler.
3 Attachment(s)
Back from the painters, the rear wing and the Spoiler King rubber roof spoiler...
Attachment 47073 Attachment 47074 Attachment 47075 |
I like the roof spoiler!
Nice progress, very clean setup; keep it up :thumbsup:
Nice RL :thumbsup:
In for updates. |
That trunk spoiler is awful. It totally killed the smooth lines of the RL rear end. :2cents:
I'd agree with that, just a bit too much. I think the roof spoiler with the aspec lip spoiler would look really good.
I did not like the spoiler at first too.... but it grew on me. nobody is perfect.
Off to have a 4 wheel laser alignment done....
5 Attachment(s)
Boring as it seems but a necessity. The photos tell the story... no dramas.:drag:
Attachment 47068 Attachment 47069 Attachment 47070 Attachment 47071 Attachment 47072 |
A few more random shots......
7 Attachment(s)
This next to my Holden SS Commodore Ute...
Attachment 47024 Attachment 47025 Attachment 47026 Attachment 47027 Attachment 47028 I saw this and realized it is a USDM RL.... in Tokyo. Attachment 47029 final shot.... peace out!:thumbsup: Attachment 47030 |
I am in love, this car is 1 one of my inspirations, I wish I can get RHD Legend out here
Nice work! I also want to get a RHD out here but obviously need to be patient.
Largus Coilover
(Post 15186626)
http://i74.photobucket.com/albums/i2...ps6928dd3e.jpg http://i74.photobucket.com/albums/i2...ps442c30f0.jpg http://i74.photobucket.com/albums/i2...ps24ee6230.jpg http://i74.photobucket.com/albums/i2...ps94a354cc.jpg http://i74.photobucket.com/albums/i2...psa8d8b4c8.jpg I saw this and realized it is a USDM RL.... in Tokyo. http://i74.photobucket.com/albums/i2...psead25fe3.jpg final shot.... peace out!:thumbsup: http://i74.photobucket.com/albums/i2...psbfa2840d.jpg I've enjoy watching the progress of RL build come together. As you know aftermarket parts for the RL is hard to come by and even harder in the USA. I've been trying to get my hands on the Largus coilover and only found a few in Japan - Largus.retail.jp doesn't ship to the USA and Nengun.com with has good prices until you put in shipping! Plus I've sent emails and haven't got a response yet😞! Can you help suggest a site that does ship to the USA and has reasonable prices! Thanks in advance. I know a lot of others RL enthusiast will enjoy this information! |
