XM Radio Tuner Location
Anyone knows the exact location of the XM Radio Tuner in my RL and how can I access it ? I've read some posts that it is located on the left side of the trunk, behind the carpeting. Is this true ? If so how do I remove that carpeting ? I did not find it an easy task, or I am missing any "tricky" moves ?
If anyone would have some pics about the exact location of XM tuner, that would be appreciated as well![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
Many thanks in advance!
Yup, you are right, it is in the trunk on the drivers side, just about in the middle of the trunk (before the hump).The carper is molded and will not easily bend, and you have to becareful of it. Start by removing the cargo hooks (the plastic grey ones that are for grocery bags, etc) and then simply pull on the carpet to pull it back. You will have to bend it, just becareful not to bend it too much.
Chris
Chris
Thanks CFoote for your prompt and clear explanation !
Also I'd need to know if my XM Radio (and XM NavTraffic) service gets disconnected if I unplug and physically remove the tuner from my car? Will it work if I reconnect it back ? Or do I have to call in to XM customer care to reactivate it ? Anyone has experience with it ?
MetalGearTypeS
08-29-2016 08:28 PM
