Sprint Treo 650 Help
Yes another question about the pairing connection for the RL. I did a search on my question however I could find an answer. So here it goes.... I am able to pair my Treo however, when I cut off my car and return I have to start the whole process all over again. Is there something I'm missing? Any assisntance will be highly appreciated.
I have a Cingular Treo 650, but I guess they all work the same.
I am assuming that you have the Bluetooth enabled on your phone 'cos if it isn't then all bets are off
Only thing I can immediately think of is that you haven't set up a trusted pair between your RL and phone. A trusted pair enables an automatic connection between 2 named Bluetooth devices, and if you haven't set one up then it would, I believe, result in the symptoms you are complaining of.
If this is possibly the cause, look up the trusted pair section in the manual and follow the instructions, it works fine for me.
Pete
Pete
MonkeyTrucker
12-12-2017 08:59 AM
09-17-2015 09:01 PM
