Question for anyone using the USA-Spec PA15-ACU-XL!
I recentlly extended my y harness cable so it would reach further and I cannot tell if it has affected quality or not.
One thing I noticed is that it sounds like more sound (and better quality sound) is coming from the left side of the car rather than the right.
To check this I set the balance all the way to the left (sounds pretty good and loud) and then all the way to the right (sounds softer and doesn't sound like I am hearing all the instruments).
Can any of you guys check this out real quick by hooking up your ipod and setting the balance all the way to the left/right and seeing if it sounds better on either side...I need to know if I need a new harness or not.
Tried that, definitely louder and on the driver side, im beginning to think this is just the way it was before but I can't be sure until someone with an unmodified harness tries it out.
What about other Audio sources? What did you use to make the splice connections?
I have only tried iPod interface, I will try a straight RCA connection when I get home, I drove to work today and could hardly tell the difference. I am going to do the wiring one more time, this time I will solder each wire (all 16 on each end lol) and use 20 guage (so the cable extension isn't an inch in diameter lol)
I meant like CD or Radio. You can't rule out your XM receiver, HU, Amp, or speaker connections unless the USA spec is the only source that does it.
Hmm thanks, I will try with the CD player, either way I cut out the old extension and have started over with 20 gauge solid core wire AND I am soldering each connection this time. I spent 4 hours last night doing this perfectly and I only got 1 half of the cable done. Whatever the result is I am going with it haha.
Sounds good on both sides for me. Although lately at random times, I'm unable to switch songs unless I do so using my iPhone. Music would play but my controls are frozen. I'd go into the audio screen and playlist, artist, songs, etc are blank.
Hmm interesting...sometimes when I switch albums it will go to the third or second song in the album but nothing like this. It may happen once every 30 album skips or something so not a big deal
navtool.com
31
11-16-2015 08:30 PM
DerrickW
11-15-2015 05:52 PM
