Buzzing noise in speakers
Old 04-13-2014, 07:51 AM
ShagJagJim's Avatar
Hi people, does anyone start their Rl and get a buzzing noise from the speakers. It sounds like the engine idle noise is coming from the speaker ..
Old 04-13-2014, 08:12 AM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
When you open the driver's door, does it go away? If so, it's the ANC module and can be disconnected in the trunk.
ShagJagJim (04-18-2014)
Old 04-14-2014, 05:17 PM
dahatter's Avatar
I'm having the same problem. Where in the trunk is the ANC module located?
Old 04-15-2014, 07:52 AM
oo7spy's Avatar
In the right (passenger) quarter panel of the trunk, you will find the amplifier.
There are three harnesses that go to the head unit. The other harness is an ANC module that you can unplug to disable the system. Here are what the radio harnesses look like.
Old 04-15-2014, 08:22 AM
dahatter's Avatar
Thank you!
Old 05-02-2014, 05:28 PM
ShagJagJim's Avatar
Hi I found out that the Buzzing was coming from the drivers side speaker in the door. It sounds like it is shot. If you can play a cd then open 1 door at a time and listen for the buzzing noise.
Old 07-21-2014, 09:25 AM
AcuraRLjak's Avatar
Did you find out if the speaker was defective or was it the anc module?
Old 10-16-2014, 05:48 PM
ShagJagJim's Avatar
Thumbs up Buzzing in Speakers
Some people would say that the ANC module causes the speaker to buzzz. I say please check your alternator, it may be on the way out. The speakers no longer buzz, once I replaced my failed alternator....
Old 10-16-2014, 07:10 PM
oo7spy's Avatar
Thanks for following up with your solution.
Old 01-17-2016, 08:03 PM
3rd Gear
Jerrod Mercer's Avatar
Are these pictures of the amp / anc harness still available? Thanks!!
Old 01-19-2016, 10:04 AM
oo7spy's Avatar
Here is the stereo wiring harnesses. The ANC is the only harness on the opposite side.
Jerrod Mercer (01-19-2016)
Old 01-19-2016, 11:02 AM
3rd Gear
Thanks, oo7spy!
I am experiencing buzzing in my front driver side speaker when the ANC is active (mostly when idle around 1,000 RPMs). When I disable ANC using the diagnostic menu, the buzz goes away. Unfortunately, over time, the buzzing has managed to blow the speaker. I'm hoping if I completely disable the ANC system before I replace the speaker, I'll be good to go.
Old 02-15-2016, 04:34 AM
scottsan's Avatar
I'm having this on my driver's side, but only when in D or R. Park is quiet.
Old 02-17-2016, 02:37 PM
ksu1018's Avatar
So anyone have the true solution to get rid of the buz?
Old 02-17-2016, 04:09 PM
oo7spy's Avatar
Here's one from post 8.
Old 04-09-2016, 07:14 AM
Maintenanceman's Avatar
I have exactly same problem with my Legend, driver side speaker acting just like that, strange buzzing noise and brrp brrp when listening music. Noticed it few days ago.
Old 04-09-2016, 08:44 AM
Made little bit more investigations.
That sound appears from idle to 1500rpm then its gone.
No effect if the ANC is off or on, no matter if the car is on park or on gear.
Maybe bad speaker or altenator?
Old 04-09-2016, 08:29 PM
oo7spy's Avatar
Could be.
Old 06-10-2016, 12:54 PM
I think that it`s not the altenator, that brrp brrp noise is coming even the car is not idling, just ignition on.
Old 06-13-2016, 10:14 AM
3rd Gear
I ended up replacing my amp with a used one I found on ebay for $50. Solved the buzzing issue completely. The ANC module is the small grey box attached to the amp (see photo), make sure the replacement amp includes this piece.
Alternatively, you can simply unplug this module as our mentor/guardian angel @oo7spy has advised.
oo7spy (06-15-2016)
Old 06-15-2016, 07:48 AM
oo7spy's Avatar
What'd you call me?!
Old 07-19-2016, 02:02 PM
Just got this buzzing/brrrbing noise sorted out, replaced the speaker and it is gone
Old 05-30-2019, 11:20 AM
Lowpass's Avatar
Did you buy a new speaker from Honda? I have the same problem. Drivers side.
Alternator is new btw as someone mentioned...
Old 06-05-2019, 09:55 AM
Walfunk's Avatar
This is tremendous! is there any way I can hook an aux cable to any of these pins?? I have a harddrive where I can store all my mp3's I would like to hookup......
Old 06-05-2019, 10:05 AM
Walfunk's Avatar
@007spy do you happen to have the back of the radio and the back of the dvd unit as well?
MrHeeltoe
20
02-23-2023 01:54 PM
SexyRL
4G TL Problems & Fixes
08-19-2016 10:03 PM
xsilverhawkx
10-05-2015 11:00 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Buzzing noise in speakers
