Inner and Outer Temperature Display do not work on startup. Please help me diagnose.
Old 06-18-2018, 10:19 AM
ajorona's Avatar
Smile Inner and Outer Temperature Display do not work on startup. Please help me diagnose.
When I start up my 2005 Acura RL, the outer temperature display in the instrument console, and the upper temperature display for the climate control do not light up. Then, after driving for a period of time, they magically come on. When the upper temperature display is not on, I cannot use the A/C. this SUCKS in the summer. Once in a blue moon, both displays work when I start up the car. But, for the most part, I have to drive for 15-30 minutes until the temperature displays decide to turn on. The battery is working fine and I checked all the fuses in the driver's side fuse box. I am nonplussed as to what to do. I'm hoping it is an easy fix like a fault relay or switch. Where should I start to diagnose?
Old 06-18-2018, 11:46 AM
Received 8,574 Likes on 6,625 Posts
Sounds like you got some loose connections in the back. I'd start there.
ajorona (06-18-2018)
Old 06-18-2018, 09:09 PM
ajorona's Avatar
loose connections in the back? What do you mean the back?
Old 06-20-2018, 01:46 PM
projektvertx's Avatar
https://acurazine.com/forums/2g-rl-a...ay-fix-957702/
ajorona (06-21-2018)
Old 06-21-2018, 12:51 AM
ajorona's Avatar
I found my weekend project! Going to reflow the board Saturday morning and see if it fixes the problem. I am somewhat skeptical that it will but it's worth a try, not like I have anything better to do.
Old 06-22-2018, 09:01 PM
ajorona's Avatar
I was expecting to see poor soldering joins but these look fine to me
Old 06-23-2018, 11:17 AM
ajorona's Avatar
I am going to resolder it today because maybe some joints are cracked and dry, I can't tell just looking at it. Today I drove the car though and the outside temperature display was not showing. This leads me to think that this is not an issue with the electrical in the upper display. I would like to test components in the B-CAN system where both the outside temperature in the multi-information display and the inside temperature in the upper display are members, but I don't have diagrams.
Old 06-23-2018, 03:37 PM
ajorona's Avatar
Yep, this did not fix the problem. It is not poor solder joints on the dash information display.
Old 06-24-2018, 08:31 AM
Ouch, I honestly thought it would be that...
ajorona
07-09-2019 06:16 AM
UWgrad
11-18-2009 01:19 PM
dnd2984
09-27-2005 09:52 AM
UWgrad
09-02-2004 10:53 AM
UWgrad
10-30-2003 02:26 PM
Quick Reply: Inner and Outer Temperature Display do not work on startup. Please help me diagnose.
