HIDS from DDMTuning...55w or 35w Ballast?
So I'm going to order HIDs today or tomorrow for the RL. After looking on some BMW forums, I noticed the 55w ballast gives MUCH brighter output. I believe stock ballasts are 35w. Is the conversion as easy as replacing OEM ballast with the new one? How hard is it to remove the ballast compared to removing just the bulb? Check the Link below to see...
35watt vs 55watt HID
http://forums.audiworld.com/showthread.php?t=1637222
DDMTuning link to HIDs:
http://www.ddmtuning.com/Products/DD...ast-35W-or-55W
I appreciate any help asap.
Love you all.
Love you all.
Are you talking about the Fog? I think you need a harness so you don't burn your factory wiring...HID 55 watt is easy enough for Fog...just make sure you buy the harness to protect your car wiring...I don't know about the D2S...Its good enough for me....but I am also getting a retrofit...
No...regular lowbeams. Fogs I will stick with 35watt as that is what is recommended as the heat buildup on the 55watt is very high. I just need to know if I can replace my OEM 35w lowbeam ballast with a 55w slim ballast instead. And James...what aren't you getting done!?
I am pretty much doing what everyone else on the forum has done...but more lights!! For example my LED emblems and LED Puddle Lights....can't wait to post some pics next week! Also...I am getting some halos in my headlight...no CCFL since the vibration cause its to break and its very easy to do...might do some LED halo behind the ring so it comes out almost like the CCFL....keep ya posted
Ooo...I am sure you could...but I haven't really checked that out.
i would stay away from DDM. go with a quality company like TRS (The Retrofit source)
55w is nice. im rocking 55w x 6 ballast. on my RL
here is a video of it at 55w with 1 projector
ojmcduffie (02-22-2012)
http://youtu.be/-zx8AjkaxT8
yes it was. you do need to route the ballast connector through the headlight and seal off the hole with some butyl rubber rope. TRS also sells this.
99% of HID Ballast with the D2S/R connection use a 9006 Connection. and it does not affect AFS at all. i also did a lens swap on the projector to a old pair of Clear Kia projectors ive had for years.
Well Carbon I stuck with what I knew and went with the 35w. Thanks for that website though this is the order I just placed from them.
Products
1 x D2S: Morimoto 3Five (35w) (3FiveD2S) = $45.00
Kelvin 6000K
1 x H11: Morimoto Elite HID System (MotoEliteH11) = $150.00
Kelvin 6000K
Wire Harness H11
Wire Harness Type Heavy Duty Relay
Ballasts Morimoto 3Five (35w)
Sub-Total: $195.00
USPS Priority Mail: $9.18
Coupon TRSRCFS: -$9.18
Total: $195.00
its a pain in the ass. my first set did not come out perfect or OMG so clean. they are black and it hides the flaws unless you really get down there and look at them. they are H11 as well. i was thinking about selling them when it warms up
all 6 projectors lit up.
Quad retrofit in the headlight
HEAVY_RL (02-23-2012)
its still in the teens temperature wise. not exactly my favorite working conditions. in the spring time i will offer headlights and foglights. ill discuss it with a mod first so i don't get crap for not being a vendor
Ah i forget that other parts of the country get cold...haha. Yeah I would discuss it with a mod of course. TRS emailed me this morning telling me my ballasts are on backorder till March 5th!!!!!!!!!!!! AAAAAAAHHHHHHHHHHH
Matt is great guy. he will hook you up. which looks like he already did. i like the 6k color but the 5k felt bright for me. and carbons mod of fogs is still in process for me.
i was going to do the 55w route like carbon but didnt want to worry about sealing and what if i didnt. + with the morimoto bulbs i already get flashing lights from on coming traffic. you will love the look.
ojmcduffie (03-01-2012)
I'm not quite sure why you say DDM is not quality. I purchased a DDM HID Slim Ballast Kit with 55w, 5000K for my 2000 Accord. I installed it in December 2009. My mom has the car now. Only two notes:
First, the fuse that came in the wiring harness was defective. Replaced it and it was fine.
Second, I flash my high-beams a lot. In the Accords and the TLs, this turns on the low beams. The DDM ballast don't like to be "flashed". The would sometimes not fire after doing this. I had to rewire it so the low beams did not come on when I flashed the high beams.
After correcting this two small things, I have not had any problems with them in the over 5 years I have owned them. I'm about to by some for the fogs on my 2003 Acura TL.
BTW-The 55w, 5000K on the Accord were a bit too bright. If I pulled up behind a shiny car at night, the reflection was intense. If you live in the city, go for the 35w (which equal the factory brightness). I live in the semi-rural area, so I needed the 55w.
DDM is garbage to me. too many quality control issues with the ballast. says 35w power and in real life it could be 25 or 40. The bulbs the supply within the HID kit are garbage the poor quality bulbs have alignment issues with the return wire which affects the beam pattern. Also the bulbs put out way to my UV and will damage your reflector bowls.
You cannot expect to get a quality kit for $45 shipped. when the the quality kits cost 3x as much. Also NEVER put HID's in a reflector headlight setup, that reflection that you spoke of is called glare. Glare can cause serious accidents just as the glare from a sunset can disrupt your driving.
So the next time you decide to dig up a 3 year old thread to argue about a product you should know a thing or 2 about what you are talking about. I have been in the Headlight Junkie game since 2002. I know a thing or 2 about headlights, i try my best to share knowledge of the do's and dont's in the headlight world.
From what I have gathered, DDM has become cheaper over the years. To assume that the product from 6 years ago is automatically the same as the product today is foolish. Changes in the market can drive decent companies to go all out cheap in order to save their bottom line.
The "cheapest" HID setups I would ever consider are Morimoto. $40 for bulbs and $110 for ballasts. Even the quality of those is noticably less than top notch products.
Hey all... New member here... I am trying to post a new thread but can't see how so I am hoping that I can get replies here.
I have an 03 Acura TL that I need a new ballast for. I am looking at the conversion kit between HIDeXtra and DDM Tuning. Pricing is about identical but HIDeXtra comes with a better warranty.
I also would like some coaching on the splicing of wires. If I should be starting a new thread for this, please explain how.
Thanks!!!
Thanks!!!
Thanks!!!
Thanks!!!
Stay away from DDM tunning. I have bad experience on my 03TLS. Check out also The Retrofit Source.
The following 2 users liked this post by M T L T L:
oo7spy (07-10-2015),
projektvertx (07-10-2015)
Thanks!!!
Thanks!!!
Your question isn't really model specific though. I would stay away from any ballasts that cost less than $70 and bulbs that cost less than $40/pair. Follow MTLTL's advice and go to The Retrofit Source. Everything they sell is quality stuff. If you are going to use cheap hardware regardless, I would go with the warranty, because they are going to fail or have a high defect rate.
As for splicing, you should not have to splice any wires. If you do, you likely bought the wrong thing. ebay has all sorts of harness adapters if you can't find a ballast that plugs into your stock harness. For tutorials on splicing, use YouTube, and practice on something other than your car.
