2006 RL HFL module
Old 08-02-2016, 12:41 PM
Paradisecove's Avatar
2006 RL HFL module
My blue tooth for my phone has stopped working in my 2006-RL. The controlling buttons on the steering wheel do not activate the system. Where is the HFL module located ?
Old 08-08-2016, 02:19 PM
Update, have found module location. It is located right kick panel (passenger side) just above fuse panel. the connector is green. You will need 10 mm swivel socket to remove.
Old 08-08-2016, 03:42 PM
Torch & Pitchfork Posse
TampaRLX-SH's Avatar
Received 1,806 Likes on 793 Posts
If you need to replace the BT module, they are not cheap. But I remember a few posts (perhaps search on replacing BT module) where the part # for the RL was the same as the TSX module (not the TL, however). And I remember at least one member had success with replacing it with a used TSX module off ebay at a fair price.
Old 08-10-2016, 10:21 AM
projektvertx's Avatar
I have a spare HFL module sitting around in my garage. I pulled it out of an '05 but I'm not sure if it works. I'd be more than happy to ship it out to you, and if it works you can send a few bucks my way. Whatever you see fit. Pm me if you're interested
Old 08-10-2016, 05:12 PM
7th Gear
GetREALnasty's Avatar
My hfl is on but I cant seem to take it off. I didnt want to still steal this thread's shine, but its similar to his problem. My hf link is on even when the engine is not running. (IGITION not turn on), and its wont let me listen to any radio. Im assuming this will drain my battery slowly, please help my brother and I out.
Old 04-22-2017, 01:32 PM
pblocksicivic's Avatar
I just went through that Getrealnasty, I just unplugged mines and put it back and it came off! Don't know how long it will last tho. Im thinking to upgrade to the USA Spec for a new HFL and music audio feedback.
Old 04-23-2017, 07:49 AM
The USA Spec unit seems to garner a lot of positive reviews. Go for it!
Old 06-20-2019, 10:55 AM
Chazz Da Barber's Avatar
USA Spec upgrade..?
where exactly would I find this USA Spec upgrade...
I'm having the very same problem...... tried using a used one, no luck..... gonna go new this time..... please help.......
Old 07-02-2019, 05:07 PM
6th Gear
Dank1079's Avatar
I know it's 3 years late, but do you still have that HFL? I just ran a diagnostic through the hidden menu and my HFL is bad, which explains why it's never worked!
Old 07-05-2019, 01:30 PM
2007 LSM KB1 Tech w/CMBS
stevieray's Avatar
Try eBay or car-part.com, you can usually find one on car-part for $50-75. 2005-2008 HFL modules are compatible with the KB1 but anything ('09-'12) past that are not. Good luck---
Old 07-09-2019, 09:51 AM
Dwayne Jackson's Avatar
https://www.usaspec.com/p-314-bt45-acu.aspx
Old 01-09-2022, 01:35 PM
8th Gear
litlerob's Avatar
I know, dead thread, but it's still relevant. It seems Honda/Acura were playing where's Waldo with the HFL unit. On 06 MDX it's behind the center console. On 06 TL it's behind the interior lights. I just wanted to make sure that on an 2006 RL it is behind the Passenger kick panel....?
Old 01-11-2022, 05:39 PM
Mike734's Avatar
That’s were it is on my 06RL.
litlerob (01-11-2022)
Old 03-07-2022, 12:52 PM
HenryW's Avatar
Thats where it is on a 05 RL. Decided to unplug the cable as i dont really use the function anymore.
Old 05-20-2022, 07:14 PM
5th Gear
DHeat914's Avatar
Unhappy
hello guys new member here long time lurker. found a lot of useful tips and tricks on here. the handsfreelink is stuck on and i cant use the radio. i disconnected the HFL about a year ago because of the battery drain in my 2006 RL but about a month ago is when the HFL screen suddenly turned on and it stays on for about 30 mins after the car is off. i checked the buttons and they work. plugged it back on but the secret diagnostic screen showed it was bad so i ordered a replacement from ebay. installed it today and its responding but still wont turn off. any other suggestion are appreciated im dying without my music
slickrab
05-09-2016 09:37 PM
coupe freak
05-08-2016 09:09 PM
TomHuz
04-21-2016 08:50 AM
paperboy42190
01-24-2016 06:05 PM
Quick Reply: 2006 RL HFL module
