2005 RL nav screen all pink-now what
Old 10-27-2012, 01:00 PM
Flygirlpainter's Avatar
Cool 2005 RL nav screen all pink-now what
I have a 2005 RL and the other morning the navi screen turned pink, it was 45 outside, a few times it flickered,,,thought after it warmed up it would turn back but it has not,, it has been in the 80's. Is the screen toast??
Old 10-27-2012, 05:44 PM
HEAVY_RL's Avatar
Received 1,037 Likes on 843 Posts
do you have anything aftermarket that would cause the plug to come loose or interrupt the signal?
Old 10-28-2012, 06:31 PM
No aftermarket anything, I figured it was just cold,, but it was 90 today and still pink,,at least it still works,,,,but looks weird
Old 10-28-2012, 06:51 PM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
45 is not cold, and I'm even from Texas. (You aren't talking Kelvin; are you?) Commercial electronics are usually rated to 0 degrees C. Automotive electronics should be rated to -40 degrees C.
You either have a bad connection, a bad signal source, or a bad screen. My guess is that the green level has been lost in one of those places.
Old 10-29-2012, 07:01 AM
db22's Avatar
Use the diagnostics menu (3 finger enable) and test the screen colors to determine the color rendition ability of the screen.
Old 10-29-2012, 10:14 AM
Matt W's Avatar
Yes do what he said. I believe you have to hold map, menu, and cancel.
oo7spy (10-29-2012)
Old 10-29-2012, 12:29 PM
db22's Avatar
Thank you for your support. ( would have issued a warning before the specifics because the member may get enthusiastic and start playing with yaw angles).
oo7spy (10-29-2012)
Old 08-04-2016, 10:55 AM
5th Gear
Hydrohaven's Avatar
Flygirlpainter, were you ever able to resolve the issue? I have the same problem. I purchased a replacement display monitor on ebay and that did not fix the problem. I followed the suggestion on this thread to access the diagnostic menu and when testing the colors, green is definitely missing. There is no aftermarket gear inline. Any thoughts from the experts out there? I'm thinking I may unplug and re-plug all the connections a few times, or wiggle them to see if something is loose.
Old 09-20-2016, 04:55 AM
VeNoMiZeD's Avatar
Did anyone find a fix for this? Besides buying a new/used unit? My 05 RL screen works but is a pinkish color to it now.
Old 11-18-2016, 10:53 AM
pink screen
Still pink! Im used to it now
Old 12-20-2017, 09:28 PM
Tidy Whitey's Avatar
I have the same issue! And sometimes if I hit a pothole or something and the car jerks the screen turns red for a bit. Anybody have a solution or an idea? It's annoying to say the least.
Old 12-21-2017, 06:45 AM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
Hmmm, pink NAV screen? I heard somewhere that means the car was used for a while by a Mary Kay sales rep.
Old 02-09-2018, 05:18 PM
hugous's Avatar
I don't have pink but yellow, It stays 70% of the time, not sure if it is LCD or other loosing part
Old 02-10-2018, 10:10 AM
projektvertx's Avatar
Bad LCD?
Old 02-14-2018, 06:46 PM
hugous's Avatar
After testing color using 3 finger method, found out it lacks of blue. For those have pink navi, it lacks of green
Old 05-07-2018, 03:36 PM
hugous's Avatar
Plan to change the NAV sceen, is there anyone have instruction? I think I need to remove the wood trim first.
Old 05-22-2018, 03:49 PM
hugous's Avatar
UPDATE! I just had time to change my screen from the one I took off from junk yard, still have same issue. I guess it's not LCD though, what is next part to check? Maybe bad head unit?
Old 06-25-2018, 01:10 PM
beekermartin's Avatar
Any updates? My screen went pink for a bit today. I assume the screen is the culprit.
Old 08-08-2018, 05:50 PM
hugous's Avatar
It's not the screen, it's the navigation unit in the trunk. The video control board went bad. I am living with it now....
Old 09-22-2018, 02:49 PM
Lorelei Barnes's Avatar
how did you get to the two front screws? Manual shows on in back under the center speaker and two in front. I cannot see them through the vents and i am afraid to break soething by prying...
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
lanechanger
10-13-2015 10:56 AM
Joe Avesyan
09-29-2015 03:57 PM
Quick Reply: 2005 RL nav screen all pink-now what
