Where to get DTC descriptions
Go Big Blue!
Anyone have a source for DTC descriptions? Are these codes an industry standard or specific to make?
At any rate, I went into the system diag screen (still fishing for the problem with my CMBS
) I saw that I indeed have 8 DTC's in the log. They are all the same code - B2206. They weren't there a month ago. Probably not related to the CMBS thing but still want to know what it is to see if it's important or minor
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
I did find this for a VW, but no idea if it is correct. Do all OBD II computers use the same code schema or does it vary by manufacturer?
http://forums.vwvortex.com/zerothrea...ostid=11655863
DTC B2206 RR Window Switch Stuck in Up Position
Then I found this
http://www.eobd2.eu/DTCL.asp
B2206 Generic ECU Configuration Mismatch
And these two, take your pick!
http://www.obd-codes.com/trouble_cod...body-codes.php
http://www.troublecodes.net/OBD2/Bcodes.shtml
B2206 Gyroscope Error
Then I found this
Go Big Blue!
Oh, I like the Gyro error possibility! Hope that's what it is. That's the yaw sensor. The RL uses a "tuning fork" style gyro to measure lateral movement.
This is input for the nav system to help swivel that vehicle position icon on your screen in realtime. It's also important input to the CMBS system (where I'm having problems).
I've definitely got to find out more about this error code. I had 8 in the log. No time stamp so I can't tell if they all occured at teh same time or have been accumulating. Thanks Chas!
Jamus22
06-11-2023 10:08 AM
quanaman
01-09-2023 07:33 PM
