When's a good time to replace timing belt/water pump/tensioner?
#41
Hello: Am currently replacing timing belt on 2007 Acura RL. Went just fine until I put the new marked belt on and had it jump about 7 teeth on both camshafts. Maybe it wasn't fully tensioned. Anyway, the problem is getting both camshaft gears on #1 TDC. The front one isn't too bad, but the rear one jumps when turned with a wrench so that setting it on the timing mark is hard (nearly impossible). Any ideas?
#42
FkNo!TheyRdstroyinEvrting
#43
Does anybody know of a dealership running a special on the timing belt/water pump service? Hamilton Honda used to have one waaaay back for less than $500. Would love to find one in that price range in the NJ, PA, DE or MD areas. Please let me know. Thanks!
#44
That price would be really good. In meantime if you don't find one, check this: https://acurazine.com/forums/second-...t-kits-888928/
My advice is go to Rockauto (lower than amazon), buy the Aisin kit. The Gates one for 40 bucks less will be tempting, but it's Gates pump is a risk. Aisin is the same OEM supplier together with Yamada to our dealers.
@163 bucks, and you find a good mechanic to do it, you could still get away with 500 or less.
Walfunk (01-10-2019)
#49
#51
Please someone from DE,NJ,PA or MD get me a reputable Honda/Acura mechanic. These dealers either won't give me prices, leave me on hold or the quotes are outrageous. West Chester Acura: full service is $1895. Timing belt only $1500. What?
#53
good luck
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
