Water coming out of arm rest, HF link stuck & dead battery
So in a nutshell, my 6 month old Bosch battery (best there is to buy around here) died. Like dead, dead, clock reset, Navi reset, etc. At the same time, HF link got stuck also. And window sometimes goes up instead of down or other way around. I think I found a cause - see video below. Any thoughts where this water is coming in?
same thing happened in my 07. i suspect the sunroof drains need blowing out and i need to check the drain plugs by the rear tires. same with a dead battery. i have unplugged the hfl module but i either have a bad ac relay or just a bad battery.from what info i could gather. i need to load test my battery and i have a new relay on the way.
Mikki LaCombe
05-30-2020 03:19 PM
