Turbo honda legend kb1 #2007 (acura rl #2005)
Crazy Russian
![Thumbs up](https://acurazine.com/forums/images/icons/icon14.gif)
As I know we made the first Turbo Legend (RL 2gen) in Russia and maybe even in the world
We didn't open the engine and didn't modify transmission and suspension.
The target HP was 350 at flywheel.
So I decided to install turbo from Mitsubishi EVO9 TD05HR-16G6C-10.5T
Also U-Power.ru installed custom intercooler, custom intake box with zero filter, custom downpipes and turbo exhaust, custom two additional fuel rail with Siemens 20375 injectors, sparks Denso VK22PR-Z11, bypass valve Turbosmart, boost 3-port solenoid, actuator Kinugava 0.45 bar (6.5psi).
AEM wifi + 2 EGT
All that was tunned by R2Racing via UniChipQ+ Driver for management additional fuel injectors And Modified Orig ECU
366HP at graph are not the last because then we tunned car on the road. At one moment we got 393HP but I asked to reduce it.
The stock dyno was 240HP on the same dynomachine.
So I get 120HP extra![Butt Head](https://acurazine.com/forums/images/smilies/butthead.gif)
![](http://s001.radikal.ru/i195/1401/95/1ffe3b6e85b8.jpg)
![](http://s006.radikal.ru/i214/1401/69/4e2d625068f7.jpg)
![](http://s020.radikal.ru/i713/1401/e4/8412739cb1d6.jpg)
![](http://s019.radikal.ru/i630/1401/bb/229b403274f0.jpg)
![](http://s017.radikal.ru/i437/1401/5f/e7ea4115a176.jpg)
![](http://s14.radikal.ru/i187/1401/8e/12e1202ba885.jpg)
![](http://s43.radikal.ru/i101/1401/4f/b61fb4eae9f3.jpg)
AEM wifi + 2 EGT
![](http://i062.radikal.ru/1401/bd/930dc831a710.jpg)
The following 12 users liked this post by MyKL:
Carbon Legend (01-23-2014),
Chans (01-10-2014),
HeartTLs (01-27-2014),
ichi d (01-10-2014),
IntactACK (01-09-2014),
and 7 others liked this post.
![Bow](https://acurazine.com/forums/images/smilies/bow.gif)
We have never seen an RL even come close to 240 HP. AWD dynos consistently come in around 205-210, and disengaging the prop-shaft for FWD reads ~220.
I wonder if the Legend is tuned differently whether that be in the gears, ecu, or elsewhere. I'm sure it's also possible that the dyno readings here don't match US dynos for whatever reason besides metric-vs-imperial (240 PS = 236 HP). I just don't want people thinking their stock RL runs 240 whp.
Regardless of that, 125 HP extra is amazing and should be commended. Also, 340+ ft*lb of torque...
![Drool](https://acurazine.com/forums/images/smilies/drool.gif)
The 3.5 in my Accord put down over 240whp stock (granted that was in a FWD manual vehicle) and I've seen 3.5 TLS's put down similar numbers stock. I'm sure the RL motor has close to the same amount of power. I bet the RL reduces power once the driveshaft is disconnected resulting in the other people's dynos coming in so low. 220fwhp is a little on the low side for a Honda 3.5 tuned on 93. However, looking at his RL on the dyno it appears they are only running the front wheels, so who knows. There are so many variables to consider when doing dyno runs
The AWD dyno numbers at ~210awhp make more sense to me. Nonetheless good to see someone making some power with the RL.
justnspace (01-09-2014)
Crazy Russian
I speak English not so good. And some moments cause the not understanding.
So, that dyno shows less than Driveshaft HP and more than wheel HP. It measures Only front wheel. As I know all wheel dyno shows more HP than single dyno. Anyway the difference is much more important for me )))
MyKL (01-10-2014)
ichi d (01-10-2014)
Crazy Russian
I have two videos when my car was under construction.
So you will see all parts (elements).
There are winter in Russia, and winter wheel, so it's not comfortable to do time attack drags.
wowsers!
flexer (01-31-2014)
Crazy Russian
Hondata and R2Racing tech told me that.
But you can take a risk and try )))
Iakonafuji (01-11-2014)
J-series addict
Videos would not work for me.
Actually, the ECM doesn't control the SH-AWD feature of the RL, the RL has a separate module for that which is on the CAN network and gathers only sensor data from the ECM such as TPS, VSS (speed), etc. The SH-AWD module also obtains other data from other modules elsewhere and is basically an interpreter of this info to operate the AWD system.
So in short, I'm reluctant to believe that it the TL-S j35a8 ECM doesn't share (and won't share) the same exact information as the RL j35a8 ECM that's required by the RL's SH-AWD control module to function properly across the CAN network.
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
flexer (01-31-2014)
Crazy Russian
J-series addict
Knowing how these cars work from electrical standpoint, I see no reason for it NOT to work. The ECM's are practically the exact same. Even down to programming parameters and software versions. The only difference that I could see was a circuit inside the RL ecm that was related to running a RFM (Radiator Fan Module) of which allows the RL to have complete control over the radiator cooling fan motors as opposed to the TL-S only having dual fan speeds...each speed being controlled with its own relay.
Crazy Russian
No sir, I'm saying that (IMO) it WILL WORK.
But why hondata can't offer for us flash pro ? And for new TL with SHAWD?
J-series addict
The RL ECM however is a something I don't understand and quite honestly you make a great point. Hondata uses VINs to identify its compatibility (as well as software security) with the ECM it's modifying. It could be as easy as inputting a TL-S VIN into the RL's ECM prior to using Hondata. Of course this requires using an HDS (or comparable) scan tool/interface to change the VIN. This is also must be done in the vehicles immobilizer.
Crazy Russian
For example r2racing did MDX on the reprogrammed orig ECU
http://www.r2racing.ru/tuned_by_r2r/...acura-mdx.html
![](http://s017.radikal.ru/i429/1401/ee/fab5b908f9bd.jpg)
J-series addict
Reprogrammed with what?
What about knock control, are you running anything for this?
What's "fake" crank data? Do you mean manipulated or intercepted crank data?
The RL is great and all but I'm really beginning to question the tuning now. You can make just about any car run more fuel (for boost compensation) but if not done correctly and accurately, it will be at the engines expense. Especially if the engine has to depend on a piggyback controller. Is the car being tuned with a wideband or EGT atleast?
Crazy Russian
I don't know how to say it in English.....
Open orig ECU, unchip (take off, take out) microchip, download flash, find charts, correct ignition and VTEC, upload to microchip, insert into the car )))
It's all good with knock because R2Racing tech used pro special equipments. But the detonation was the main restriction for boost! The J35A8 Head is the worse of what you can imagine
yes
What do you mean: correctly and accurately? I show the dyno
Of course))))
how without it?
And now I use "AEM wifi UEGO + 2 EGT" just to control that all are right.
Of course))))
how without it?
Crazy Russian
The explanation of the specialist
Originally Posted by Mura R2Racing
Unichip does manage additional 6 injectors and modified closed loop operation of both front AF sensors.
We could not effectively change ignition by Unichip because of two crank sensors in RL, we've seen lot of misfires as a result any noticeable ignition variation. That's why we've decided to re-programm stock ignition maps. Ignition maps of ECU have been reprogrammed with Piasini Serial Suite. Also was changed VTEC point.
Regarding knock control, we have possibility to edit both Knock Retard maps and Knock Ignition Limit, but decided to leave them stock.
Türk (01-16-2014)
Hey there.
I want to install DRL to my car like yours.
See the thread:
https://acurazine.com/forums/2g-rl-2005-2012-76/where-put-drls-903320/
Can you give some comments on that thread?
What kind of system do you have? How are they activated else.
Kind regards,
Türk
See the thread:
Kind regards,
Türk
