TPMS (tire monitoring)
AcurAdmirer
Originally Posted by miner
Some low-life stole all 4 valve caps from my tires (RL not even 1 month old). Does the TPMS require special valve caps?
TPMS does not have any dependencies on the valve caps. You shouldnt be using the steel factory ones anyways. They tend to seize over time and Acura had recalled them.
If you got the gray plastic ones stolen, I believe theyre like $.10 to replace.
office monkey
Yeah some idiot stole mine like a half year after I got the car. Sad humans are that pathetic to rip-off valve caps that are cheap. I could see if they were made of platinum but sheesh...lame
AcurAdmirer
I guess I thought it was cheap of Acura to put those crummy little plastic caps on in the first place. Why anyone would want to steal them is beyond me.
Originally Posted by Mike_TX
Are you serious? I've used steel (chromed) caps for decades and I've never had any problem with them. I've always found the cheapie plastic caps either strip out the first time you put them on a little crooked or they harden and crack and fall off.
Plastic, of course, isn't subject to this.
AcurAdmirer
Originally Posted by jftjr
It's more of an issue in the snow belt. The valve stems are bronze, the caps were aluminum. Add some salt water (from road salt) and you have two dissimilar metals with an electrolyte -- which if you remember your HS chemistry, is a battery -- and you get a galvanic reaction that causes the valve caps to corrode onto the valve stems.
Thanks for the clarification.
AcurAdmirer
The ones on my car ('06) - and stolen - are metal with a green rubber O-ring on the outside.
AcurAdmirer
No PAX - regular Michelins that come on base RL
Otherwise, I don't know, since standard Acura caps are chintzy grey plastic jobbies.
Yes, they did - that answers my question about the caps.
BTW Mike-TX, the traffic around the 'Plex' was a mess this weekend. Was in East Dallas and had to drive to Azle, TX Sat. afternoon.
AcurAdmirer
