TPMS Code 37
Where are these wheel sensor batteries located? Are they owner-serviceable, or do they require dealer involvement? How long do they last? What kind of battery?
jfprl, which year RL do you have - how long since these batteries were new on your car?
The batteries are inside the wheel sensors attached to the inside of the wheels. As far as I know they are not user replaceable. I believe the whole sensor needs to be replaced. I am at 50,000 miles and 2 1/2 years old.
It looks like there is no way to replace the battery in the TRW TPMS used in the RL. Actually, the TPMS appears to be a JV between TRW and Michelin called En-Tire Solution
http://www.trw.com/extlink/1,,,00.ht...om#38amp;DIR=1
If you believe Wikipedia, 7-10 year battery life for TPMS is required.
http://en.wikipedia.org/wiki/Tire_pr...itoring_system
I just reviewed the pages in the TRW and Wikipedia links provided by Chas2 above. I am concluding that, unlike some other cars, the RL's tire pressure system is a type which does NOT have to be re-initialted or re-programmed when changing or rotating tires. Rather, it "learns" to reconfigure itself so that it properly identifies which wheel location is associated with each sensor.
Is this correct?
Is this correct?
That is correct. The car does relearn after driving a few miles or after some time sitting. I think that after a certain number of responses from each corner of the car, the computer resets itself to the signals it is getting from each corner of the car.
I believe, when the ignition is off, the TPMS is interrogated at a very low frequency, say once per hour or longer. But when the ignition is on, it interrogates once every minute, and that interrogation rate may even increase with speed of the car. But the point is the car learns that the TPMS sensors have changed positions on the car, and reflects that info in the MID.
Jamus22
06-11-2023 10:08 AM
