Thermostat Water Neck Help
Hey everyone I'm new here. Been lurking and researching with this site since I got my 2005 RL a couple weeks ago. I got it super cheap with a burnt exhaust valve, so I'm in the process of removing the front cylinder head. It's nothing like the D and B series Hondas I'm used to working on. Right now, I'm stuck at removing the water housing that connects each head, below where the TB is. I got all the nuts off except for the back, lower one. I just can't seem to get on it and when I can there is no room to rotate a wrench. I can't get a socket on it because the heater hose pipes are in the way. I'm hoping someone has a tip for me on this one. Here's some pics of what I'm talking about.
you need a short socket or a short with swivel socket to remove that bolt also extension, the part you try to remove is the coolant passage between front bank and rear bank, this also housing the EGR gas passage. There will be MLS gasket on each side and they are re-useable.
projektvertx (04-23-2017)
