started my car and a whole bunch of lights came on Help
so it is 5 degrees over here and starting my rl this morning which is a wonderful 2005 a bunch of lights came on
sh-awd
vsa
abs
check engine
afs (which comes and goes gives me a stroke sensor code which was changed stayed off for a week and came back)
the codes I am getting are
126-5
b2141
b2190
b1404
78-7
77-1
78-17
86-1
anyone can help me here car has a new battery in it and I drove to work shut the car off and turned it back on and the lights stayed off I know it was cold but I don't think these lights should be coming on because of that
my afs light comes and goes sometimes it stays on and when I shut the car off and start it the light goes away
sh-awd
vsa
abs
check engine
126-5
b2141
b2190
b1404
78-7
77-1
78-17
86-1
Battery or alternator (voltage regulator inside) is on its way out.
likely just battery due to low temps is reading low. If you have a battery charger, charge her up and try again, or replace
FkNo!TheyRdstroyinEvrting
From what i read on here, try changing the ground cable on the battery. It's 10 bucks, and i read here it caused similar stuff.
This appears to becoming a real common problem on the later RLs.
I keep seeing this popping up in this forum.
My 2011 developed this problem early summer 2015, there is a TSB 09-025 applies to 2009-2012 which I present to my dealer requiring the SAS sensor to be replaced.
Dealer replaced the SAS and AFS sensor corrected these errors. Covered under the AcuraCare warranty.
I too replaced my good Acura battery and nothing was solved.
Carbon Legend
08-05-2016 05:21 PM
nore03
05-04-2016 02:10 PM
Carbon Legend
01-11-2016 10:10 PM
