service rl leased?
Old 06-28-2007 | 05:25 PM
vipgelsi's Avatar
8th Gear
service rl leased?
Hi i have a leased 2006 rl i am due for oil change soon and was wondering if i could go to a local shop for a oil change / chain store because my closest acura dealership is hour away. will this void my lease terms? or if i keep records will i be ok
Old 06-28-2007 | 05:36 PM
lland's Avatar
Just keep your recipt showing the mileage when you had the serivce and you'll be fine.
LL
Old 06-28-2007 | 07:21 PM
Mike_TX's Avatar
AcurAdmirer
This comes up from time to time, and it's worth saying that all you are required to do under a lease is maintain the car in good repair. That does NOT mean you have to have all the "recommended interval services" performed. Those are mostly cash cows for the dealers.
I've done many leases, and all I typically do is change the oil and filters (oil and air) (sometimes at the dealer, sometimes elsewhere, sometimes myself), and I have never had those "recommended services" done. Never ever been an issue. Which is good, because I think it's criminal to charge people $300 to oil their door hinges and adjust their parking brake cable, and I refuse to do it.
Old 06-28-2007 | 10:57 PM
vipgelsi's Avatar
8th Gear
Thanks !
Old 06-29-2007 | 07:08 AM
miner's Avatar
It would be a good idea to keep a pocketful of drain plug crush washers in your car to give to your local Oil change shop to use. Typically they don't use washers when changing the oil. This aids in not over tightening the drain bolt.
Mike734
12-10-2021 01:25 PM
08KBP_VA
10-22-2019 01:55 PM
lanechanger
10-13-2015 10:56 AM
thegipper
09-28-2015 01:01 PM
jmaxima03
09-27-2015 10:22 AM
Quick Reply: service rl leased?
