RL problems in extream cold weather
Old Jan 16, 2009 | 07:57 PM
fongz's Avatar
Exclamation RL problems in extream cold weather
It has been very cold here in Toronto lately, it was -2F today, and my car was park outside, when I start it this morning, my VSA and Sh-AWD lights are both on, after I drove it for half an hour, when I restart it, the warning lights went off. I guess it must has something to do with the cold weather, I am just wondering if anyone has the samilar experience.
Old Jan 16, 2009 | 09:06 PM
nore03's Avatar
Randy is the Future
Yeah this morning when my girl came in the house from making a run to Mcdonalds she said that 3 lights came on. She said the VSA light came on the tire pressure monitor like came on and the SH thing that is on the back of my car light came on but when i went down stairs to the car the only light that came on was the Tire pressure monitor but that usually happens in the winter.
Old Jan 17, 2009 | 12:21 PM
RL06tech's Avatar
Its ice interfering with the sensors. Turn the car off, restart and drive it at more than 20mph, everything goes back to normal. This procedure is true for any time you have the VSA and SHAWD lights pop up. If the warnings remain despite one or 2 "resets", take it to a pressure wash and give the brakes a good wash, if that doesn't do the trick, its dealer time.
Old Jan 17, 2009 | 01:18 PM
jfprl's Avatar
Not as extreme, but it was 31 in Houston the other day and my AFS light went on. At the next light I restarted the car and everything was OK.
Old Jan 17, 2009 | 05:11 PM
vas25tl's Avatar
The Box
Damn cold messing with all the sensors.
Old Jan 21, 2009 | 11:04 PM
Legend93's Avatar
Had the same problem the other day in Ottawa. VSA and SHAWD lights came on. The car contacted AcuraLink and I got a messgae saying to shut the car off and restart it. I tried it and the lights went off. It's just the extreme cold messing with the sensors.
Old Jan 21, 2009 | 11:40 PM
motegi's Avatar
No trouble with mine in -10 F last week. Knock on wood!
Old Jan 21, 2009 | 11:45 PM
Blazing GT's Avatar
my car runs fine.
Old Feb 9, 2009 | 12:26 PM
Llevar's Avatar
8th Gear
Happened to me a couple of times this winter as well. Also in Toronto. When the car heats up things go back to normal. What's alarming though is that it seems that not only do the sensors not work but the actual features are switched off.
Old Feb 9, 2009 | 06:02 PM
kenny5's Avatar
Anyone have any problem with the navi display screen when it is really cold?
Old Feb 9, 2009 | 08:01 PM
fongz's Avatar
The screen takes a while to response to any input, and it's darker while it's cold.
Old Jan 14, 2011 | 05:02 PM
joshsways's Avatar
5th Gear
Has anyone heard anything new about the warning lights (VSA and SH-AWD) coming on in cold weather? I have an 05 RL and the warning lights come on anytime it hits -15C or so. The problem is that I live in a city that gets a lot of snow and it usually gets cold after a big snowfall. So when these lights appear when you start your car, and you're parked in a snowbank, you can't get out! I have to wait until my car gets really toasty and then restart it to get the functionality of my AWD!
Like Llevar said above, when the warning light is on, your car loses the functionality of the SH-AWD. So when the light is on my car turns into a FWD and the tires just spin and I'm completely stuck. After 10 mins of idling, I can restart the car and if the light doesn't come on, all four wheels kick in and I'm no longer stuck!
There must be some way to fix this! For those of us driving this car in extreme winter climates this is a big problem!
Anyone have any new info?
Old Jan 14, 2011 | 06:24 PM
BluNosr2's Avatar
Yikes, that is a problem - half the reason I went for an RL is the winter practicality of AWD and rust-free aluminum bits to resist the salt effects.
I didn't realize when the lights come on you lose the associated systems, SH-AWD is a biggie for winter no doubt about it. Keeping fingers crossed that here in NS we normally don't get anything below -15C very often
Old Jan 14, 2011 | 09:35 PM
csmeance's Avatar
the RL's electronics are very sensitive to voltage drops and spikes just like many other German cars, and in the cold weather batteries probably aren't putting out enough CCA's to get the car and electronics running properly.
The factory Acura Battery isn't the greatest in the world, I suggest you have them checked out and make sure they can deliver the proper power levels to avoid issues.
Old Jan 15, 2011 | 05:55 PM
christopher1's Avatar
yes, me too..
in ct or when i wash my 05 RL i get 2 lights AWD and check emission light. i went to dealer for recall and asked him about it he said RLs have allot senors. i just reset the ecu and delete after i wasj my rl in the cold. still love my RL!!
Old Jan 15, 2011 | 08:32 PM
nsx_2k's Avatar
csmeance is correct. My car '05 did the same thing after it was once parked outside where the temps dipped to -12 degrees in MN. What I noticed was that during the long crank during the cold, the battery voltage dips just enough to throw off the other electronic modules, hence the error codes that resolve with a restart.
I also agree with csmeance that you should check out your battery to ensure that it is up to snuff to handle the frigid temps.
I believe the errors with SH-AWD, VSA are related to power brown out. The AFS error, though, "may" be due to the stroke sensor mounted on the driver rear shock failing or acting up.
Old Jan 17, 2011 | 01:27 PM
joshsways's Avatar
5th Gear
This is really helpful! When I think back, the starts have been long and a bit painful (sounding) due to the cold. I usually trickle charge my battery before each cold season, but I haven't done that yet this year. And I think the amount of times I've seen the two errors (VSA and SHAWD), have been much fewer in past years. Looks like I've got my work cut out for me.. I'll charge/replace the battery and post to let you know how it worked.
Thanks!
Old Jan 17, 2011 | 06:08 PM
BluNosr2's Avatar
It was -10C this morning when I started my 06. Everything seemed fine until about 10 seconds out of my driveway when what I can only describe as a soft "howl" started, kinda like blowing across the top of a bottle LOL...it varied with engine speed and seemed to sound like it was coming from behind the nav screen, went away after about 30 seconds of driving
Old Jan 17, 2011 | 06:14 PM
getakey's Avatar
that sounds like the "30-35 mph" howl
Old Jan 17, 2011 | 07:51 PM
BluNosr2's Avatar
This is the only time it's done it though, on what was definitely our coldest morning of the winter so far. It seemed odd to have gone away so quickly, since it took maybe 20 seconds of driving to go silent and during that time I am basically just coasting downhill from my driveway (I live at the top of a long hill) - I applied a tiny bit throttle on and off to see if the noise changed with throttle application and engine speed (which it did). Not even a budge from the coolant gauge or any heat to speak of before the sound just went away.
When I left the office tonight after the car sat for 10hrs in the parking lot it was just as cold, and everything was normal/dead silent.
It is supposed to be even colder tonight and into tomorrow so I'll see what happens on tomorrow's start.
Old Jan 17, 2011 | 08:07 PM
BluNosr2's Avatar
Also I should add I drove an 05 that had a noticeable propeller shaft "whine" when cold, that didn't go away during the entire 20min test drive in the middle of winter - even the salesman admitted he heard it - and this is definitely a different sound I heard this morning from my 06. The 05 whine almost sounded like an intake whistle or bad alternator/spark interference from the stereo, and you couldn't really locate where it was coming from.
Old Jan 18, 2011 | 11:54 AM
getakey's Avatar
I have 05 and the noise only occurs in a very narrow range 30 to 32 mph and only for the first 5 to 10 minutes of driving. The noise sounds like it is coming from right behind the Nav screen and sounds almost like a brief radio interference - more of a whir than a whine. It is worse (louder and longer) the colder it gets, but will happen in a temp about 55 or colder. I'm in SF,CA area, so we do nto get your extremes.
Old Jan 18, 2011 | 12:21 PM
nralpmet's Avatar
2005 RL with over 200k KM
Another Toron...Mississauga RLer here. Yes, had the SHAWD and VSA errors on Monday morning. Another common cold weather problem is the TPMS warning.
Old Jan 18, 2011 | 08:20 PM
BluNosr2's Avatar
OK, I definitely have the 30mph "howl". Did it again this morning, and only at exactly 50km/hr for about the first 30 seconds of driving after sitting outside overnight.
And, I still have until April for warranty on the powertrain based on the car's in-service date (the warranty on the 06's was 5 yrs 100,000kms in Canada, I am at 81xxx kms).
Where can I get a copy of the TSB for this to take to the dealer? Does someone have a copy they can email me or something? The threads I found all link to the now offline TSB website.
Old Jan 19, 2011 | 10:43 AM
getakey's Avatar
I don't think there is a TSB for the 30 mph howl
Old Jan 19, 2011 | 11:12 AM
Chas2's Avatar
It is a May 2008 Acura ServiceNews
Whine, Whistle, or Howl
Between 30 and 40 MPH
Currently Applies To: ’05–08 RL
A bad propeller shaft center support bearing can
cause an annoying whine, whistle, or howl if you’re
driving between 30 and 40 mph and the bearing is
cold.
[picture here which I cannot insert with current tools at my disposal]
To check for a bad center support bearing, here’s
what you need to do:
1. Raise the vehicle on a lift, and make sure that it’s
securely supported.
2. Have someone start the engine, shift into Drive,
and slowly accelerate until the speedometer
reads between 30 and 40 mph.
3. While standing under the center support bearing,
use a stethoscope to listen for noise coming from
the bearing.
• If you hear noise coming from the bearing,
replace the propeller shaft. Refer to pages
16-42 thru 16-45 of the ’05–08 RL S/M.
(Online, enter keyword PROPELLER and
select Propeller Shaft Removal and
Propeller Shaft Installation from the list.)
• If the bearing is quiet, continue with normal
troubleshooting.
Old Jan 19, 2011 | 11:27 AM
getakey's Avatar
I stand corrested.
Chas - have you heard anyone reporting that the bearing failed?
I'm well out of warranty and not anxious to get repaired
Old Jan 19, 2011 | 01:05 PM
Chas2's Avatar
Actually you are correct. I do not believe there is a TSB.
This was a ServiceNew article. ServiceNews looks to be much more informational in nature, alerting techs of known problems/issues and how to address them. Some articles are purely informational, like why the RDX uses synthetic, different from every other Acura vehicle, or how certain cleaning products can damage finishes and not use them, or how some products can fix common complaints dealers are seeing, etc. TSB's seem to be more serious in nature, and provide specific procedures to address problems not documented elsewhere.
That said, I am not sure what makes an issue worthy of a TSB.
Old Jan 19, 2011 | 06:42 PM
BluNosr2's Avatar
On the good news front, made a call to my local dealer today describing the issue, my service advisor immediately remembered another RL coming in with the same problem and that there was a "service notice" issued, he found it and is ordering the new shaft and processing me under the powertrain warranty (I still have a few months left on the 5yr/100,000km Canadian powertrain warranty)
Old Jan 26, 2011 | 05:53 AM
037's Avatar
037
just wanted to let everyone know that I've had the same xmas tree of lights couple days ago. The temp was in the high teens low 20s. SH-AWD, VSA, Check Emissions.
Haven't taken it to the dealer yet to check out but the message cleared after a short while.
Old Feb 2, 2011 | 01:17 PM
037's Avatar
037
just to give everyone an update, I took the car to the dealer and they did catch a code, I don't remember the exact details but they ran a computer update and asked me to keep the car overnight to see if any problems occur.
I will add info here as soon as I get the paper work back.
Old Feb 2, 2011 | 03:21 PM
miner's Avatar
Knock on plasti-wood.
Old Feb 4, 2011 | 07:09 PM
BluNosr2's Avatar
Just had the propeller shaft replaced under the standard powertrain warranty (5yrs runs out in April, I have about 50k miles on the odo now), no more cold weather "howl" at 30mph.
And knocking on wood, no warning lights with -17C weather
Old Feb 23, 2011 | 11:29 AM
037's Avatar
037
just wanted to add the codes attached to my issue in case this helps anyone else:
Cause: PCM
123505 Diagnostic trouble codes/ programmed fuel injection - retrieve codes with the HDS, read data: 5260, WA 0.60
FC: 03214
no idea what it means but now you have it.
Old Feb 23, 2011 | 08:48 PM
Taylor W's Avatar
I've been having the same issue with the sh-awd light and vsa light in the cold. I find around -18c or lower the issue occurs and unfortunately thats pretty much every day in the winter here.
I took the car to the dealer and the first time they did the diagnostics they said it was probably just a glitch, but it kept happening every morning. I took it back and upon further diagnostics they said it was the sh-awd control unit or something. Don't remember what it was called but all I know is installed it will cost me about 1,200 dollars.
Old Feb 25, 2011 | 10:33 AM
tofer.tofer's Avatar
I had this issue in Minneapolis when it was -20F a few weeks back. Once I drove it down the road and restarted it, it went away. This doesn't happen all the time when it's cold. It has been just as cold a few more times and not an issue. This car in general isn't the best cold weather car. My washer pump works great when it's above freezing, but when it gets cold, its a trickle....frustrating
2005 RL Lakeshore Silver
Old Mar 2, 2011 | 06:15 PM
skyrader's Avatar
The SH VSA light has come on twice for me as well recently in th moring when I get off work. Temps were mid teens. All I do is turn the car off and restart and the SH AWD light goes off and all is well. As for the washer fluid, sounds like what your using isn't for cold weather. Check the temp rating on the brand you are using. I have no problem with the washer fluid even at -15F.
Old Jun 23, 2013 | 10:17 PM
oo7spy's Avatar
You should be shopping for a new battery.
Old Jun 24, 2013 | 06:23 AM
sOLLEx's Avatar
Sounds like you have a faulty brake switch...cheap fix
Old Jun 24, 2013 | 07:36 PM
oo7spy's Avatar
We have seen batteries last as short as 6 months here. If there is a weak or bad cell in the battery, the RL is going to expose it.
I would consider a new battery before assuming the brakes are to blame. Is it possible to swap batteries with another car to test?
