RL Navi Problem
Old 01-26-2008 | 08:35 PM
CL6's Avatar
CL6
My only car is a Bus
RL Navi Problem
You start the car, the Acura blue navi/world screen is on then the screen very quickly (i.e. .5 seconds) changes to the enter code then it goes black with no way to enter the code, do a voice command... etc. It was working a few weeks ago. The navi disc is in the back.
Any ideas..?
Old 01-27-2008 | 10:02 AM
Mike_TX's Avatar
AcurAdmirer
Since it's not initializing, it sounds like it needs to be rebooted.
Try ejecting the nav DVD disc, then with the key "on", put it back in and let it go through its startup routine.
If that doesn't work, try disconnecting the negative battery terminal for 5 minutes, then reconnect.
If neither of those works, my guess is the drive is bad. (But of course, I'm no Tech. )
Old 01-27-2008 | 12:47 PM
larrynimmo's Avatar
07 RL (non-tech)w/06 Nav
obviously if its under warranty, take it to the dealer...if not, remove the disc and clean it. If it still doesn't work go to the diagnostic screen and see what is going on. There is a post by "Acura2007RL" that tells you how to enter the diagnostics. If you have problems with the DVD player, you can relatively easily remove it and send it to Alpine for a flat rate repair.
I have done this for my Ebay Nav unit that I bought and installed
SidhuSaaB
05-30-2020 12:40 AM
LoneRonin
01-04-2016 01:03 AM
Kres43
1G RDX (2007-2012)
10-03-2015 07:16 PM
MoAbbas
10-03-2015 07:44 AM
tristann616
1/2G MDX (2001-2013)
09-22-2015 11:40 PM
Quick Reply: RL Navi Problem
