Quick Check for Crush Washer Size, Oil & Rear Diff
Master Graphic Artist
From my research the oil change crush washer is the standard 14mm and the rear diff drain and fill washers are 20mm?
Can I pick these up at a local auto store or should I go to Honda / Acura parts desk to pick them up?
Anyone else have an issue with aluminum washers seizing up? I bet the dealer over torqued my oil drain bolt.
I couldn't even get it off with a Snap-on cordless impact, I had to use a breaker bar with another pipe to remove that sucker. I couldn't separate the washer from the bolt either so I threw in a spare brass washer. Will probably replace that thing with one of those easy drain plugs.
Feels so much better to do the job yourself and know you did a good job.
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
IIDXholic
10-08-2015 07:53 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
