Question about Crank Pulley Upgrade
Hi
Let me say Thank you for all the amazing helpful threads. I have a 06 RL Tech (95k) and am doing a complete timing belt service this week and have read on here about installing a aftermarket Crank Pulley. Can someone please help me, Im not sure which one to get. Ralco is fine Im just not sure if I should get the Underdrive Crank Pulley or the regular Crank Pulley, I am assuming the Underdrive is the lower and the other is the top pulley? Which one will give me added performance?
Also any suggestions of additional maintenance I could do at the same time as the timing belt kit.
I am using these parts:
Timing Belt Honda -14400-RCA-A01
Idler Roller / Pulley Koyo OE -14550-RCA-A01
Tensioner Roller / Pulley Koyo OE - 14510-RCA-A01
Water Pump & Gasket Honda -19200-RDV-J01
Hydraulic Tensioner AISIN OE - 14520-RCA-A01
Front Camshaft Seals x 2 Honda - 91213-R70-A02
Front Crankshaft Seal Honda - 91212-R70-A02
Serpentine Drive Belt Honda - 38920-RCA-A03
Thermostat Tama - 19300-PR7-A02 with gasket
Silicone Sealant Hondabond - 08718-0004
No.
Under drive means it will under drive the crank by using a smaller sized pulley. It still is a crank pulley. (Lower)
The stock diameter aftermarket pulley will give the same benefits because it's lighter. 1lb vs the stock OEM 10lb pulley.
Every one purchases the stock sized aftermarket pulley because they don't want to run into problems under driving the engine
Plenty of people have purchased and documented it. Find the "search this forum" toolbar in the forum to do a search.
Like justn said, you want the stock size. The RL electronics are already hard on the charging system. You don't want to cut into that any more.
echodigital
03-25-2016 09:32 PM
richardparker
03-11-2016 09:42 AM
