Part number for door courtesy lens?
I was trying to change out the filament bulbs that are the door courtesy lights into LEDs. Well, I screwed up on two of them in that the flat bed screw driver slipped and pretty much made nasty marks on the lens itself. Happened more than once for that one lens. So basically I want to replace the lens, and the little oval housing that houses the lens because that got damaged too...if the price is reasonable.
![](http://i21.photobucket.com/albums/b296/sleepinlionhart/0628101827.jpg)
The thing is, I can't seem to determine which part is the lens. I looked here:
http://www.discountacuraparts.com/pa...layCatalogid=0
and it seems that it's part #31, but why does it say "Lamp lens Back"? And I can't find the same part for the illustration of the rear door. And for the oval housing for the lens that got damaged, it looks like it's part #30, yet again it has an odd name of "Black Black Back." Somehow I don't think that's it because it doesn't give a choice of colors.
Then there's the "puddle lamp" which seems to be the housing since it is available in different colors: http://www.discountacuraparts.com/pa...layCatalogid=0
Not sure if puddle lamps= courtesy lamps.
![Confused](https://acurazine.com/forums/images/smilies/confused.gif)
