P0706 And P1717 Error Codes?
has anyone received these error codes p0706 or p1717?:whyme:
P0706 Open in Transmission Range Switch Circuit
P1717 I cannot find, but that range of error codes include: P1706 Open in Transmission Range Switch Circuit P1709 Problem Transmission Gear Selection Switch Circuit P1730 Problem in Shift Control System: Shift Solenoid Valve A and D Stuck OFF Shift Solenoid Valve B Stuck ON Shift Valves A, B, and D Stuck This information comes from the Garage Sticky above, which includes Error Codes. |
Originally Posted by TampaRL
(Post 11545748)
P1717 I cannot find, but that range of error codes include: P1706 Open in Transmission Range Switch Circuit P1709 Problem Transmission Gear Selection Switch Circuit P1730 Problem in Shift Control System: Shift Solenoid Valve A and D Stuck OFF Shift Solenoid Valve B Stuck ON Shift Valves A, B, and D Stuck This information comes from the Garage Sticky above, which includes Error Codes. How did you find the codes? |
From this forum.
There is a sticky called: 2G RL Garage version 1.0--DIYs, TSBs and other useful information In that post there is a link to: List of all MIL engine codes FYI, I cannot find any references to a P1717 for Honda nor Acura anywhere else. Other manufacturers use it, and they all reference Tranny circuit or solenoid issues. |
P1717
Just to put it up there.
Code P1717 D drive light blinks, MIL on, Tansmission range switch ATP RVS switch open. |
I am getting a repeat code: P1706, 1999 Acura TL, brand new transmission, and more. The code states it is a Neutral Safety Switch; this was replaced a few months ago, with a new Manufacturer brand, not used, or off- brand.
Oddly, another symptom just also appeared - the right turning light now blinks faster than the normal speed, whereas, the left turning blinker is still normal. |
| All times are GMT -5. The time now is 09:25 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
