P0706 And P1717 Error Codes?
P0706 Open in Transmission Range Switch Circuit
P1717 I cannot find, but that range of error codes include:
P1706 Open in Transmission Range Switch Circuit
P1709 Problem Transmission Gear Selection Switch Circuit
P1730 Problem in Shift Control System:
Shift Solenoid Valve A and D Stuck OFF
Shift Solenoid Valve B Stuck ON
Shift Valves A, B, and D Stuck
This information comes from the Garage Sticky above, which includes Error Codes.
How did you find the codes?
From this forum.
There is a sticky called: 2G RL Garage version 1.0--DIYs, TSBs and other useful information
In that post there is a link to: List of all MIL engine codes
FYI, I cannot find any references to a P1717 for Honda nor Acura anywhere else. Other manufacturers use it, and they all reference Tranny circuit or solenoid issues.
I am getting a repeat code: P1706, 1999 Acura TL, brand new transmission, and more. The code states it is a Neutral Safety Switch; this was replaced a few months ago, with a new Manufacturer brand, not used, or off- brand.
Oddly, another symptom just also appeared - the right turning light now blinks faster than the normal speed, whereas, the left turning blinker is still normal.
Jamus22
Jun 11, 2023 10:08 AM
