need size..
See if these bulbs are in the acuraoemparts.com on line catalog and let us know. The other advice is if you are going to replace one bulb in that area, you might as well replace all. The other thing people have done, not necessarily on this forum, is to remove the light and go to radioshack to match.
The other interesting experiment is to try LED lighting from someone like this...LEDs may have the wrong color and be too directional when compared to incandescents, but could be a cool mod if you are in there anyway...
Whatever you do, let us know!
http://www.superbrightleds.com/cgi-b...nstrument.html
There is a TSB that shows you how to do this, or some instruction sheet. Look in the 2GRL garage and get access to the Acura server that houses all this info. There is a message from the moderator csmeance that gives you some steps that allow you in through a backdoor.
check it out...is this the bulb you need?
http://www.acuraoemparts.com/delray/...All&vinsrch=no
look at item 002.
here is a potential candidate photo. You will have to take it out to be sure
http://www.alibaba.com/product-gs/35...NEW_Wedge.html
look at item 002.
Dabu
03-26-2015 08:35 PM
