Need a little help installing the cargo net
OK. I'm a reasonably bright guy, have to be, I'm a doc, right? So why am I having such a hard time with installing the cargo net? Just received it today from Curry Acura and have been going through the instructions. I simply cannot believe this...have to remove the plastic trim in the back of the trunk, then find a way to loosen up the rings on the trunk floor, then pull off the side trim, then unscrew.
And I thought trying to figure out which way to install the TL's cargo net was a little complicated! (OK, it took 15 minutes to figure out the right way).
I have a simple question. The instructions say to pop up the plastic at the bottom of the metal rings on the trunk floor. For the life of me I can't do that! What did people use and how hard did you have to pull? I've tried for most of an hour and am just scarring the plastic. Tried a wide screwdriver, then a wide, dull spreading knife that fit perfectly into the apointed space. I'm having such a tough time with a seemingly simple task and wanted to make sure I was doing it right.
PS--A-Spec kit arrives from Curry Acura tomorrow. Can't wait!
looked at the intructions myself after buying the cargo net and the best advice I can give was pay the $30 to the dealership (like i did) and have them install the cargo net.
It is not worth the time and effort to do it yourself what a major pain it is installing a simple cargo net if you wish to use all the various hook configurations.
removing the trunk rings
Originally Posted by Ry4an
I got the plastic tabs poped up. I used a screwdriver and marked the hell out of the edge with the notch, but it popped up. When the ring is folded down it covers the marred edge nicely. The phillips screw under the cover is really hard to loosen as well -- have fun with that.
Originally Posted by jftjr
Obviously, as neuronbob has proved, installing the cargo net is not brain surgery.
'05 Acura RL - CGP/Ebony
Hmmm. That's what I was afraid of. I thought the dealership was joking when their price list for the cargo net listed both with and without installation. Little did I know.... I may just have the dealer do this, what a hassle!
It IS a pain.
asahrts
09-04-2015 05:55 PM
