Navigation antenna not working? please help
Old Sep 10, 2012 | 10:21 PM
Rockysouth's Avatar
7th Gear
Im sure that this isnt the first thread about this problem however i need help. my nav unit went on my 05 RL. instead of sending it to alpine threw the dealer I bought a new(used) unit from a 06 RL. Inside was the 2008 DVD.. The unit works (AC controls, AUDIO, settings, INFO. the navi will not find a signal!!!! so no (map or menu) I pressed MAP/GUIDE-CANCEL-MENU and then played around and got to a screen that ran a check and the Red light flashed on Antenna!!! and another screen said "antenna NG" does anyone know what may be the issue?
I pulled the radio fuse and reset the system twice. and unplugged the trunk navi unit twice to try and recalibrate it didnt work.
Old Sep 10, 2012 | 11:11 PM
Rockysouth's Avatar
7th Gear
Just wanted to drop a line. and say I am not the sharpest tool in the shed. after running the system check a few time i figured i would check just to make sure i made every connection. sure enough i forgot to plug in the antenna wire into the navi unit.
Problem solved..
Old Sep 11, 2012 | 08:36 AM
HEAVY_RL's Avatar
nice job finding the issue
Old Sep 11, 2012 | 08:39 AM
Problem solved..
Au contrarire, mon ami.
you figured out the problem!
Ol'Dave
Sep 5, 2020 02:56 PM
oyayjoe
Jan 1, 2019 10:17 PM
acurajj
Sep 19, 2015 03:47 PM
Luis J. Rodriguez
Sep 12, 2015 10:00 PM
