Leaking oil/coolant hose
Coolant is clear with a blue or green tint. Oil is dirty brown. It looks like you are by the power steering reservoir(?) and serpentine belt. Can you comment on where this hose is? How do you know this hose is leaking versus another leak dripping on it?
In other words, we need more info. Throwing parts at it likely won't help.
It is probably power steering fluid from a small power steering pump leak. That is actually a common wear and tear issue on Hondas if not all cars.
Check out posts 9-11 here: https://acurazine.com/forums/second-...g-leak-933879/
